another second chance '69 - Team Camaro Tech
Build Projects follow along start to finish
post #1 of 19 (permalink) Old Jan 29th, 14, 11:40 PM Thread Starter
andrew
little info on the car:
69' camaro project that's been in a barn for past 30 years (last registered in '82 in indiana), 71,xxx original miles, originally daytona yellow with black vinyl top/ strato black interior, matching number car with original 350/power glide trans (column shift), 12bolt rear with 331 gear, original a/c car, ps, pwr drum brake. came as a complete car, and tested the motor and it will still turn over. unsure with what direction i am going to take this build, but i will figure all that out once i get done with the metal replacement.
wahhpshh is offline
post #2 of 19 (permalink) Old Jan 30th, 14, 12:36 AM
Tim
Re: another second chance '69
Andrew, looks like a nice project, and matching numbers too!
Interesting engine compartment wiring.
1969 04A Van Nuys-built Z/28. Cortez Silver with dark blue interior and VE3. Sold Clippinger Chevrolet. Raced at Lions in LA.
ZLP955 is offline
post #3 of 19 (permalink) Old Jan 30th, 14, 12:40 AM Thread Starter
andrew
yea, not sure is up with all that to be honest. since the car has sat, someone along the way has tried to "do some work to it", but was better off leaving it alone. they tried doing everything they could to just put the ignition on a switch. but as you can see, it is haggard as all get out.
wahhpshh is offline
post #4 of 19 (permalink) Old Jan 30th, 14, 05:20 AM
Kevin
KevinW's Avatar
Andrew, you might want to check out this article: http://www.camaros.org/lm1.shtml
From your pics, I think this car is an LM1. It should be a 350/255 with a q-jet. Looks like power drums too. Kinda rare good score!
Kevin
KevinW is offline
post #5 of 19 (permalink) Old Jan 30th, 14, 05:36 AM
69-Pace's Avatar
Yeah good save and if an LM1 worth bringing back as born IMHO.
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
post #6 of 19 (permalink) Old Jan 30th, 14, 06:58 AM
Randy
Wow, that looks like a nice project! Good find
My 69 Camaro build thread:
rsgt is offline
post #7 of 19 (permalink) Old Jan 30th, 14, 07:12 AM
Ty
69&76's Avatar
Very nice find indeed
69&76 is offline
post #8 of 19 (permalink) Old Jan 30th, 14, 08:58 AM
NHBandit's Avatar
Good start. I agree to look into the LM1 possibility. If you need another opinion drop me a PM. I'm 15 minutes up the road and been messing with this old junk since the early 70s. PS.. the jack hook is wrong... lol
NHBandit is offline
post #9 of 19 (permalink) Old Jan 30th, 14, 09:40 AM
Camarodude67
you posted his car is for sale so??? 8500.00 firm....
camarodude67 is offline
post #10 of 19 (permalink) Old Jan 30th, 14, 09:45 AM
Welcome, Andrew! If the drivetrain is all original, it sure sounds like a LM1. What part of Indiana did it come from? Check here for how to decode everything: http://www.camaros.org/drivetrain.shtml
buenymayor is offline
post #11 of 19 (permalink) Old Jan 30th, 14, 11:22 AM Thread Starter
andrew
it is an lm1 car.
literally brought it home and started taking pictures to start the build documentation. didnt even bother with taking writing off the glass. its already in my shop being torn apart.
it came from anderson
wahhpshh is offline
post #12 of 19 (permalink) Old Jan 30th, 14, 11:49 AM Thread Starter
andrew
meant to say it appears to be an lm1 car. still working on decoding the vin. ill let you guys know what i come up with here in a few minutes.
wahhpshh is offline
post #13 of 19 (permalink) Old Jan 30th, 14, 02:25 PM
Kevin
KevinW's Avatar
The VIN and trim tag will only help get the build dates and whether it was a V8 car (remember the LM1 was mostly before the X-codes). The engine stamp and the VIN stamp on the engine will prove if it is an LM1 or not. Engine code should be an HR for a powerglide.
Kevin
KevinW is offline
post #14 of 19 (permalink) Old Jan 30th, 14, 02:41 PM Thread Starter
andrew
ok guys, what ive came up with so far is:
~production date is october of '68
~25,527 sequence number
~made in norwood plant
~originally daytona yellow with black vinyl top
~came equipped with power drum brakes
~standard strato black bucket seats
vin # ___ 124379N525527
cowl tag ___ 12437 NOR 154641
TR 711 76B
10C
been super busy with work today, but can provide picture of vin, cowl, pop tags if that can help you guys help me figure out exactly what this car was.
wahhpshh is offline
post #15 of 19 (permalink) Old Jan 30th, 14, 02:49 PM
Kevin
KevinW's Avatar
Build date and VIN line up fine. Pic of the POP will go a long way for the decode!
Make sure the Engine code says HR and the VIN is stamped and matches. Powerglide will have a date stamp on the trans pan, the stamped vin will be on a boss near the dipstick/starter on the angles part of bellhousing or on the very top of the bellhousing where it mates with the back of the engine.
http://www.camaros.org/drivetrain.shtml#PadStamps Scroll to bottom for pics of the powerglide Vin locations.
Kevin
KevinW is offline
