69 Camaro SS Yellow RamJet 350 improvements - Team Camaro Tech
Build Projects follow along start to finish
post #1 of 15 (permalink) Old Dec 28th, 14, 04:54 PM Thread Starter
TJ
Smile 69 Camaro SS Yellow RamJet 350 improvements
I have a 69 Camaro that I bough in Spring of 2014 and it did come with good paint and new fuel injected engine (RamJet 350). I am going to post/repost some projects to this thread that have been done. It may be a resource for someone else.
Antenna replaced thread
Retrosound Model 2 installed to replace stock radio
cont...
ttwo is offline
post #2 of 15 (permalink) Old Dec 28th, 14, 05:15 PM Thread Starter
TJ
Re: 69 Camaro SS Yellow RamJet 350 improvements
Doug's electric cutouts installed
and then RUST ENCAPSILATING, interior sound proofing with DYNAMAT and DYNALINER withdoor panels quieted
cont...
ttwo is offline
post #3 of 15 (permalink) Old Dec 28th, 14, 05:25 PM Thread Starter
TJ
I replace the interior and carpet and put new Infinity Kappa 4x6 speakers in the kick panel after cutting out a hole in just the right spot! I used OEM speaker grills in the kick panel
I also replaced the sony rear 6x9 with Infinity Kappa speakers and an Infinity 75watt per channel AMP (yes upside down since I wired it that way ) . I also replaced the plastic liner in the back with molded carpet from RICKS.
this last photo shows the loop style carpet from RICKS
ttwo is offline
post #4 of 15 (permalink) Old Dec 28th, 14, 09:12 PM
67 Camaros Rock
Joe Harrison's Avatar
Can you get a full picture of the trunk carpet and also how it fits up near the tail panel. I think I like this idea.
-Mark Donahue
My 67 Camaro Time Line
Joe Harrison is offline
post #5 of 15 (permalink) Old Dec 29th, 14, 10:02 AM Thread Starter
TJ
sure, like right by the tail light area?
ttwo is offline
post #6 of 15 (permalink) Old Dec 29th, 14, 12:05 PM
67 Camaros Rock
Yes....wondering how far it goes up to the tail lights and also how close it is the rear seat and side to side. Is it form fit to the trunk pan?
I have a 67 so mine could be slightly different.
-Mark Donahue
post #7 of 15 (permalink) Old Dec 29th, 14, 12:19 PM Thread Starter
TJ
i try to remember tonight. it fits really good, the edges are sewn and no trimming required. it is molded for sure. not just laying in there. it goes all the way up to the seat back
ttwo is offline
post #8 of 15 (permalink) Old Dec 29th, 14, 08:28 PM
Kris
Which dynaliner did you go with? What thickness. Do you think it made a big difference heat wise. Or are you going for sound deadening?
Sent from my Nexus 4 using Tapatalk
Kris Carter
67 Camaro RS
kcmoney13 is offline
post #9 of 15 (permalink) Old Dec 29th, 14, 08:38 PM Thread Starter
TJ
I went with 1/2 inch and won't really know how it does until spring here. I won't drive it until probably April or May, but I'm really going to enjoy not hearing all the road noise. I'm excited
ttwo is offline
post #10 of 15 (permalink) Old Dec 30th, 14, 08:01 PM
Kris
I bet I need to look into this more for heat reasons. Here in Florida its almost to hot to drive in the summer and I have AC. Black on black doesnt help. Thanks again
Kris Carter
67 Camaro RS
post #11 of 15 (permalink) Old Dec 30th, 14, 09:37 PM Thread Starter
TJ
putting the dynamat extreme on the floor but especially the roof would be your best bet. Adding dynaliner would be even better but it won't fit on the room under the headliner.
ttwo is offline
post #12 of 15 (permalink) Old Jan 1st, 15, 10:11 AM Thread Starter
TJ
Ricks Carpet for the trunk
Notice that the edges are finished and that it is split to fit the contour of the rear of the trunk
fits all the molding of the trunk
and slips right up to the back of the seat. If you want to cut a hole for the tire hold down you have to do that yourself
ttwo is offline
post #13 of 15 (permalink) Old Jan 2nd, 15, 05:56 PM
Jon
Nice detail in that trunk carpet.
Jon
My 72 Chevy Vega
My Garage Journal Build Thread:
jon72vega is offline
post #14 of 15 (permalink) Old Apr 8th, 15, 06:54 PM
Andrew
Andrew69's Avatar
I bet the trunk carpet tones down the muffler noise inside the car some. Can you tell a difference?
Skunk Works
Some photos:
Member # 159
Andrew69 is offline
post #15 of 15 (permalink) Old Apr 9th, 15, 05:48 PM Thread Starter
TJ
I'm sure a little bit but I also just sound deadened my entire interior with dynamat and dynaliner and between the springs of my rear seat back I stuffed a furniture blanket to muffle sound from the trunk. I figured any barriers I can place should only improve the 'quiet'.
ttwo is offline
