69 Convertible Rebirth - Team Camaro Tech
Build Projects follow along start to finish
post #1 of 11 (permalink) Old Nov 29th, 15, 10:19 PM Thread Starter
jason
67-CAM-RIDER's Avatar
Hello All,
I am going to use this as my rebuild thread. I am currently working on a 57 2dr post so this project will be on the back burner since I'm about a third of the way through the 57.
http://www.trifive.com/forums/showthread.php?t=124903
but enough about that. Here is my 69 that I just picked up
It is an original V8 that's about all I know
it appears that all the "outside" sheet metal is original and the rust has been fixed or the panels were replaced. It was repainted and then stored for the last five or so years. It is a manual top with no interior or drivetrain. 10 bolt rear end. That is the good. See the next post for the BAD!!!!
67 Camaro
67-CAM-RIDER is offline
post #2 of 11 (permalink) Old Nov 29th, 15, 10:39 PM Thread Starter
jason
Re: 69 Convertible Rebirth
OK now the BAD! I'm not sure if being negative and talking ill about past work is taboo but PLEASE if you let anyone do the following work to your Camaro STOP THEM!!!!! First will be a new floor and braces to fix this:
This is taken from the rear passenger wheel facing forward, and yes that is a bed rails or multiple angel iron used for support and some sort of square tube for a make shift subframe connector, or should I say brace connectors. I'm not sure why the rocker is cut up.
Same are looking back
more of the brace connectors
Inside the back seat
The other side
67 Camaro
post #3 of 11 (permalink) Old Nov 29th, 15, 10:49 PM Thread Starter
jason
And the carnage continues to the trunk, Do you notice that the frame rail are cut off and do not connect to anything, and the Frankenstein bracket covering the bumper holes
I did not get a photo of the wheel wells or the hack job that covered the shock towers.
I'm not sure what my option is if fix the inner tail pan? I would hate to have to cut out the rear pain pan to fix it.
I will for sure need a complete new trunk also
67 Camaro
post #4 of 11 (permalink) Old Nov 29th, 15, 10:54 PM Thread Starter
jason
And to the front:
I am not sure who was trying to put a 2nd gen sub-frame in but they did not get it to fit
overall I'm happy and since I can do the work myself I think I'm ahead of the game.
I already have another sub frame so that problem is solved.
Thanks for looking and I'll be updating in a couple of months, but will most likely have a bunch of questions along the way.
67 Camaro
post #5 of 11 (permalink) Old Nov 30th, 15, 05:01 AM
Kevin
KevinW's Avatar
Wow, I am speechless! I applaud you for taking on this and fixing it the correct way!
Kevin
KevinW is offline
post #6 of 11 (permalink) Old Nov 30th, 15, 06:08 AM
Some of the worst work I have ever seen. Have to wonder what is lurking under that paint.
dhutton is online now
post #7 of 11 (permalink) Old Nov 30th, 15, 09:09 AM Thread Starter
jason
I know the fenders and hood are new and the doors seem solid I'm really only worried about the quarters which seem ok so far
67 Camaro
post #8 of 11 (permalink) Old Nov 30th, 15, 11:49 AM
Kevin
sleepsinshed's Avatar
Whoever did that should have their tools taken away.
Kevin
sleepsinshed is offline
post #9 of 11 (permalink) Old Nov 30th, 15, 04:08 PM
Jason, Did you buy the car sight unseen ? Like Don said I'd be very
concerned with what might be hiding under that shinny paint. Good luck
with the rebuild.
my 67' build thread:
allanjs is online now
post #10 of 11 (permalink) Old Nov 30th, 15, 04:52 PM Thread Starter
jason
I saw it before I got it I'm not worried to much about the paint since I will most likely repainted it. I was comfortable with the price and I've restored cars before.
67 Camaro
post #11 of 11 (permalink) Old Dec 6th, 15, 10:23 AM
As stated before "WOW". The good news is the parts to fix it are available. Where there's a will there's a way. Good luck!
69indyz11 is offline
