1968 camaro build - Team Camaro Tech
Build Projects follow along start to finish
post #1 of 17 (permalink) Old Aug 9th, 16, 01:50 PM Thread Starter
Kurtis
1968 camaro build
I've been working on rebuilding my 68 camaro since October 2015 and thought it was time to share
The car was originally a 6 cyl base model in Butternut Yellow.
When I bought the car it had been repainted twice over the original paint. First it was painted a bronze orange then was painted over with just primer. Currently the body is in good shape with a few small rust spots
The car had a SBC 350 which I've removed and replaced with a 383 stroker that I built from scratch.
Name:	Back Passanger_1470771929959.jpg
ID:	157410   Click image for larger version
Name:	2-8-2016 1-26-14 PM_1470771950513.jpg
ID:	157418   Click image for larger version
ID:	157434   Click image for larger version
Kurtismcm is offline
post #2 of 17 (permalink) Old Aug 9th, 16, 02:26 PM
Darin
ilikeike's Avatar
Re: 1968 camaro build
Cool.
I'm partial to 68s myself.
1968 Butternut Coupe,
421" Dart SHP block
TKO 600 RR
Dutchman 9" w/3.70 US Gear Lightning r&p
Global West arms
Budnik wheels
ilikeike is offline
post #3 of 17 (permalink) Old Aug 9th, 16, 03:28 PM
Chris
Very good looking 68...can't wait to see it completed.
68 Camaro: SBC 396 Stroker motor from BluePrint and an MSD EFI.
trainedkilla is offline
post #4 of 17 (permalink) Old Aug 9th, 16, 06:30 PM
Nice project and seems to be going well. Correct year I would say.
post #5 of 17 (permalink) Old Aug 10th, 16, 06:11 PM Thread Starter
Kurtis
I will try to post each phase of the project with before and after photos and explanation of what I did
Phase 1 - subframe
I used several methods to strip the frame to bare metal. First step was to use a stripper wheel from harbor freight. Second step was to use a wire wheel on an angle grinder. Third step was to sandblast the corners and hard to reach areas.
I then welded all of the seems completely top and bottom.
I then prepped using POR15 Marine Clean and Metal Prep.
Final step was to apply POR15 paint and top coat
ID:	157578   Click image for larger version
post #6 of 17 (permalink) Old Aug 10th, 16, 06:52 PM Thread Starter
Kurtis
Couple more pics
ID:	157610   Click image for larger version
post #7 of 17 (permalink) Old Aug 10th, 16, 07:34 PM Thread Starter
Kurtis
Phase 2 - firewall
I removed the stock heater box to replace with a Vintage Air unit.
Welded a plate, smoothed the firewall and painted with POR15 and top coated semigloss black
ID:	157634   Click image for larger version
ID:	157642   Click image for larger version
ID:	157658   Click image for larger version
post #8 of 17 (permalink) Old Aug 10th, 16, 08:45 PM Thread Starter
Kurtis
Ridetech strong arms, drop spindles, coil overs, tru-turn and muscle bar installed
ID:	157690   Click image for larger version
post #9 of 17 (permalink) Old Aug 11th, 16, 10:25 AM Thread Starter
Kurtis
Phase 3 - 383 stroker
Old 350 vs new 383
Name:	File Mar 16, 12 58 47 PM_1470932591231.jpg
ID:	157722   Click image for larger version
post #10 of 17 (permalink) Old Aug 11th, 16, 04:24 PM
Great start...and the year
68 Camaro~LSx ~all motor
post #11 of 17 (permalink) Old Jan 2nd, 18, 03:28 PM Thread Starter
Kurtis
its been a while since i last posted, car has come a long way - still not done but getting close
ID:	201457   Click image for larger version
ID:	201458   Click image for larger version
ID:	201466   Click image for larger version
post #12 of 17 (permalink) Old Jan 2nd, 18, 03:46 PM
RDW
Bob
You’ve been busy, the car looks great
67 Camaro coupe 327 automatic
78 RS Camaro 350 automatic (sold)
RDW is offline
post #13 of 17 (permalink) Old Jan 2nd, 18, 03:49 PM
Looks really sharp! Congrats on the good job.
'68 RS
VitaminC is offline
post #14 of 17 (permalink) Old Jan 2nd, 18, 06:13 PM
Agree, Camaro looks nice.
post #15 of 17 (permalink) Old Jan 2nd, 18, 07:09 PM
mike
You nailed the stance, car sits perfect. I am more of a chrome guy but the black makes it yours. Nice work.
bigblockragtop is offline
