69 Camaro 383 FI swap and OD Tranny - Team Camaro Tech
Build Projects follow along start to finish
 5Likes
post #1 of 25 (permalink) Old Aug 14th, 16, 03:35 PM Thread Starter
Vega$69's Avatar
A friend of mine told a friend of his and now I'm doing some mods on his 69.
He bought it new in 69 327 TH350 car.
He just spent big $ with a local custom shop on body, paint, custom interior, power windows and locks, etc. and DSE Suspension A-Arms, Coil Overs, and rear springs and shocks. Car looks great but performs terribly.
He hates driving the car so he brought it to me. Won't even wash it! That's why it's dirty now. Actually his son brought it says his Dad won't even look at it. Lol
Complaints:
#1 Car has no power (original 327 with a few mods) won't even spin the tires
#2 Wants EFI
#3 Wants to replace the TH350
#4 Doesn't like the way it rides (too harsh)
Wants to keep stockish looking so no LS
So here's the plan. Budget is $15K-$17.5K parts and labor
New crate 383 Stroker with FAST EFI 430 HP 450 Torque
EFI Fuel Tank and in-tank pump
700R4 with custom convertor
3.55 Gears
Larger Radiator to support the motor and AC with Dual Fans and Dakota Digital Fan Control
I still have to see what's up with the suspension. No travel on the front end at all. My guess is wrong springs. Either too soft and compressed all the way to get ride height or too stiff. Also probably wrong shocks on the rear for a street car.
Car looks better then the lousy pictures I took.
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #2 of 25 (permalink) Old Aug 14th, 16, 03:52 PM
Banned
Chet
Re: 69 Camaro 383 FI swap and OD Tranny
Good plan but I would go 2004r over the 700r4. Better gearing.
onefiness is offline
post #3 of 25 (permalink) Old Aug 14th, 16, 04:01 PM Thread Starter
Vega$69's Avatar
I'm ordering tomorrow. I will be looking at the 200 as well. They run about $150 more then the 700. Ratios are really not that much different.
200r4 2.74 1.57 1.00 0.67
700r4 3.06 1.62 1.00 0.70
Vega$69 is offline
post #4 of 25 (permalink) Old Aug 14th, 16, 04:19 PM
DT
Donny
DT's Avatar
John, nice car. Is that a custom piece where radio is ?? Why not go 4l60E on trans ??
DT is offline
post #5 of 25 (permalink) Old Aug 14th, 16, 05:12 PM Thread Starter
Vega$69's Avatar
Yes it a custom dash All the center section metal was cut out and moved over. The dash pad was sectioned and recovered.
4L60E would require a little tunnel mod and an electronic controller. Trying to keep it simple
DT likes this.
Vega$69 is offline
post #6 of 25 (permalink) Old Aug 14th, 16, 06:22 PM Thread Starter
Vega$69's Avatar
This might be an Idea 6 Speed tranny in a 700R4 case
From Bowtie Overdrives
Full 4L65E (2005-6 Trans) Drive Train Retro Fitted into a 700R4
A/C Delco 5 Pinion Planetary Set
Full Torrington Bearings Throughout
THIS MEANS NO THRUST WASHERS
Reinforced Bushings covering 50% more surface area for High Torque/High Horsepower applications.
Also if you want even more we offer a Hardened Input Carrier for $175.00 (Special Order Only Must Call)
Bowtie Overdrives - View Item
DT likes this.
Vega$69 is offline
post #7 of 25 (permalink) Old Aug 14th, 16, 07:09 PM
Banned
Chet
Look at the terrible spacing between first and second. Horrible.
post #8 of 25 (permalink) Old Aug 14th, 16, 07:10 PM
Banned
Chet
That's nice. How much do they want for this? Wait, thought you wanted to stay away from electronic control?
post #9 of 25 (permalink) Old Aug 14th, 16, 07:39 PM
Electronic control means no TV cable to mess with, programmable shift points and firmness etc.
DT likes this.
1959 El Camino project
1957 Buick Caballero project
dhutton is offline
post #10 of 25 (permalink) Old Aug 15th, 16, 04:37 AM
John, you wouldn't consider going FiTech ?? With the exception of availability I am hearing GREAT things
Nice new white car BTW !
Cheers'
69' SS/RS X11 PRO-TOURING E-FORCE LS7, DSE Sub, T56 MAG, Recaro, Wilwood disc, Racepak IQ3S, SpeedTech TA/JRI CO's, Pro-Venom 250s, Forgeline CV3C 20/19 - SOLD
Sheck44 is offline
post #11 of 25 (permalink) Old Aug 15th, 16, 06:08 AM Thread Starter
Vega$69's Avatar
Cheers'
The engine package I bought comes with the FAST already installed, tuned and dynoed with 30 month 50,000 warranty
Vega$69 is offline
post #12 of 25 (permalink) Old Aug 15th, 16, 06:19 AM Thread Starter
Vega$69's Avatar
Not terrible if you want to smoke tires off the line. For a track car looking for best ET maybe.
The 6 speed in the 700 case is $3000.
Won't be using it on this build. Just thought it was interesting
Vega$69 is offline
post #13 of 25 (permalink) Old Aug 15th, 16, 06:32 AM
Banned
Chet
Yes, we all know what electronic controls do and mean. If you had read all the posts you would see that Vegas stated that he didn't want an electronic trans, that he wanted to keep it simple.
post #14 of 25 (permalink) Old Aug 15th, 16, 06:58 AM Thread Starter
Vega$69's Avatar
TV cables work perfectly on 100,000s of cars and trucks made by GM for years.
The 4L60E is a tight fit and the tunnel has to be modded the clear the tranny cooling lines.
The custom interior, carpet and console are in place and don't want to start tearing into it.
Vega$69 is offline
post #15 of 25 (permalink) Old Aug 15th, 16, 07:07 AM
Sorry Chet. Please accept my sincere apologies. I should have known better than to participate in a thread in which you have posted without getting your approval of my post prior to posting. Carry on....
And I did read all the posts first. Maybe you should get a life outside of policing this forum for guys posting similar thoughts or ideas...
barryfrise and stinger67 like this.
dhutton is offline
