My 67 L78 Build - Page 12 - Team Camaro Tech
Build Projects follow along start to finish
 57Likes
post #166 of 238 (permalink) Old May 12th, 18, 05:07 PM
Bruce
Re: My 67 L78 Build
Very nice!!!
Bruce
Donate Life, Become an Organ and/or a tissue donor
xplantdad is offline
post #167 of 238 (permalink) Old May 12th, 18, 07:53 PM Thread Starter
Keith
Originally Posted by xplantdad View Post
Very nice!!!
Thanks!
I'm going to fire up the car tomorrow.
Sosh67 is offline
post #168 of 238 (permalink) Old May 12th, 18, 08:23 PM
Bruce
Re: My 67 L78 Build
Originally Posted by Sosh67 View Post
Thanks!
Hopefully with some video
You've done a really nice job...I am very partial to big block 67's...this is my brothers...he's had it since the late 70's...
Bruce
post #169 of 238 (permalink) Old May 13th, 18, 03:13 AM
Greg
pittpens24's Avatar
Re: My 67 L78 Build
Looks great!
'68 Camaro with RS conversion
Moser 9" with 4:11
Tremec T-56 Magnum 6 speed
572 BB - CM Engines
pittpens24 is offline
post #170 of 238 (permalink) Old May 13th, 18, 07:15 PM Thread Starter
Keith
Thanks!
Hopefully with some video <img src="https://www.camaros.net/forums/images/smilies/smile.gif" border="0" alt="" title="Smile" class="inlineimg" />
I am unable to see the pic you posted. But, I am also partial to BB's.
They have very unique feel when stomping the gas and running thru the gears.
Sosh67 is offline
post #171 of 238 (permalink) Old May 14th, 18, 05:25 PM Thread Starter
Keith
A little more progress. I almost forgot to put the oil pressure fitting in. I will have to remove Z-bar to install but I can still get at it easily.
ID:	214793   Click image for larger version
ID:	214794   Click image for larger version
xplantdad likes this.
Sosh67 is offline
post #172 of 238 (permalink) Old May 16th, 18, 06:18 PM
Bruce
Re: My 67 L78 Build
Very nice!
Hopefully now you can see the pics...also you can go here to the album that the rest of them are in!
Team Camaro Tech - xplantdad's Album: Gary's Camaro
When it was new...
What it looks like now
Bruce
post #173 of 238 (permalink) Old May 18th, 18, 03:07 PM Thread Starter
Keith
Very nice!
When it was new...
Beautiful car! I love the color. That is the color of my next project!
A tiny bit more progress...
Sosh67 is offline
post #174 of 238 (permalink) Old May 19th, 18, 07:09 AM
Bruce
Re: My 67 L78 Build
Very nice Keith!
Bruce
post #175 of 238 (permalink) Old May 19th, 18, 04:46 PM Thread Starter
Keith
Driver fender on and aligned! Header, valence and hood mechanisms installed as well.
I learned an install lesson. Get the shims fittment correct, but don't tighten front end sheet metal until you have it all installed.
ID:	215281   Click image for larger version
ID:	215289   Click image for larger version
ID:	215297   Click image for larger version
ID:	215305   Click image for larger version
Sosh67 is offline
post #176 of 238 (permalink) Old May 19th, 18, 06:37 PM
Matt
Re: My 67 L78 Build
Excited for you. You'll be driving before you know it!
Can I ask what you sprayed in the wheel wells? Now that I have the bottom of mine painted I wanted to spray something extra in the wells for durability.
My Build Thread
350sshugger is offline
post #177 of 238 (permalink) Old May 19th, 18, 08:07 PM Thread Starter
Keith
Rustoleum truck bed coating - 4 coats.
Sosh67 is offline
post #178 of 238 (permalink) Old May 30th, 18, 02:49 PM Thread Starter
Keith
Aligned front end. Torqued down all ball joints. Filled radiator, gas tank and brake cylinder.
Set the timing and starter her up! Unfortunately, I don't know how to attach videos.
BTW - I have stock height valve covers with 2x tall gaskets. The roller rockers are not hitting the covers...which eliminates my wiper motor clearance issues.
ID:	216257   Click image for larger version
Sosh67 is offline
post #179 of 238 (permalink) Old Jun 6th, 18, 09:24 AM Thread Starter
Keith
Re: My 67 L78 Build
I finally drove the car last night. Maiden voyage up and down the driveway. I even drove it into and parked it in the garage. I have been fighting my brake system for over a week and finally discovered what the issue was.
I read a ton of blogs and picked up a bunch of valuable information. Unfortunately, none of it applied to my issue, but it did help me eliminate possible parts of the brake system from the equation.
I have original power disc brakes with rear drums. All SS new lines, rebuilt master cylinder, brake booster, hold off valve, and proportioning valve. This should have been a piece of cake.
Symptoms: Soft pedal, front disc engage, rears drums that did not engage. But, all lines bled correctly.
I had extras of every component, so I even swapped them out.
Solution: I had the rod at the back of the power brake booster attached to the top hole in the brake pedal. This caused the master cylinder to partially engage. This probably removed most of the pressure to the rear brakes, while still letting them bleed. Once I moved the rod to the lower pedal, it removed the pressure from the master cylinder and all was good in this world!
None of my buddies considered this possibility. They pointed at all the other parts in the system. I am just glad to be past that headache and on to sanding a buffing the paint.
xplantdad and 350sshugger like this.
Sosh67 is offline
post #180 of 238 (permalink) Old Jun 6th, 18, 05:47 PM Thread Starter
Keith
I finished up on the brakes today. I performed a gravity bleed. I opened the lid of the master cylinder, went to each brake, furthest rear first and ran a hose to a bottle with some brake fluid in it. The purpose was to keep fluid draining to the bottle with end of the hose submersed.
This process worked extremely well and drew out residual air bubbles from the lines. It also helped me find a minute leak between the caliper soft and hard line.
Tiny bubbles were constantly draining to bottle. Tightening the line eliminated the bubbles.
My brakes are working perfectly now!
Sosh67 is offline
