My 67 L78 Build - Page 13 - Team Camaro Tech
Build Projects follow along start to finish
 58Likes
post #181 of 239 (permalink) Old Jun 10th, 18, 06:39 PM Thread Starter
Keith
Installed the hood today. My daughter Shelby helped me sand and buff the hood, valence and header today. It was exhausting!
I still have some fine tuning of the hood, but it is close.
ID:	217457   Click image for larger version
ID:	217465   Click image for larger version
xplantdad likes this.
Sosh67 is online now
post #182 of 239 (permalink) Old Jun 11th, 18, 07:01 PM Thread Starter
Keith
Aligned the hood today. That was tougher than I remember!
Biggest issue I had was that I had tightened radiator core support down. I had to loosen it, shift the support with reference to the frame...which scooted the front of the fenders over a bit. It was exactly what was needed.
So, for me, not tightening portions of the front end sheet metal allowed me to get the hood aligned.
ID:	217529   Click image for larger version
ID:	217537   Click image for larger version
350sshugger and pittpens24 like this.
post #183 of 239 (permalink) Old Jun 12th, 18, 06:20 AM
Kevin
Re: My 67 L78 Build
Looking good!. Thanks for the tip on aligning the front end sheet metal, that will be handy for me.
My '69 RS Primer driver project
KJProX is offline
post #184 of 239 (permalink) Old Jun 12th, 18, 08:49 AM Thread Starter
Keith
Thanks! Be sure to tape your edges!
KJProX likes this.
post #185 of 239 (permalink) Old Jun 13th, 18, 06:23 PM Thread Starter
Keith
Finished blocking out the orange peel from the clear coat. Next stage is buffing!
ID:	217793   Click image for larger version
post #186 of 239 (permalink) Old Jun 13th, 18, 07:54 PM
Bruce
Re: My 67 L78 Build
Looking great!
Bruce
Donate Life, Become an Organ and/or a tissue donor
xplantdad is offline
post #187 of 239 (permalink) Old Jun 14th, 18, 07:48 PM Thread Starter
Keith
I installed the right rivets in the wrong location. So, out with the bad and in with the good. 67 Camaro grills used 2 types of rivets. Flat...black rivets between grill and grill trim. Stainless steel ovals between lower grill trim and valence.
I also installed the headlight hardware. I just have to line them up and then I will install the headlight trim.
Finally, I put on the correct air cleaner.
ID:	217857   Click image for larger version
ID:	217865   Click image for larger version
post #188 of 239 (permalink) Old Jun 17th, 18, 02:46 PM Thread Starter
Keith
As with everything else related to this restoration, I had my first shot at buffing a fresh coat of clear coat.
I bought a nice Milwaukee buffer. I hit all but the header and valence.
Buffing exposed a few blemishes in the paint. Nothing major. I should be done with buffing and waxing this week.
ID:	218017   Click image for larger version
ID:	218025   Click image for larger version
ID:	218041   Click image for larger version
ID:	218049   Click image for larger version
ID:	218065   Click image for larger version
ID:	218073   Click image for larger version
post #189 of 239 (permalink) Old Jun 24th, 18, 07:00 PM Thread Starter
Keith
Put the door handles, locks and cat whiskers on the car.
I also painted the bumble bee stripe.
ID:	218618   Click image for larger version
ID:	218625   Click image for larger version
ID:	218641   Click image for larger version
ID:	218649   Click image for larger version
ID:	218657   Click image for larger version
ID:	218658   Click image for larger version
350sshugger likes this.
post #190 of 239 (permalink) Old Jun 25th, 18, 03:59 AM Thread Starter
Keith
Here are the results.
ID:	218681   Click image for larger version
post #191 of 239 (permalink) Old Jun 25th, 18, 06:01 PM
Bruce
Re: My 67 L78 Build
Very nice Keith!
Bruce
post #192 of 239 (permalink) Old Jun 27th, 18, 08:18 PM Thread Starter
Keith
Originally Posted by xplantdad View Post
Very nice Keith!
Thanks! Coming to the end of this project.
Installed louvers and hood insulation.
Getting new tires and rims installed tomorrow!
ID:	218825   Click image for larger version
post #193 of 239 (permalink) Old Jul 1st, 18, 12:27 AM Thread Starter
Keith
Finished results!
ID:	218937   Click image for larger version
ID:	218939   Click image for larger version
post #194 of 239 (permalink) Old Jul 1st, 18, 09:37 AM
Re: My 67 L78 Build
Stripe looks good Keith. Did you purchase a stencil or lay it out by dimensions ?
my 67' build thread:
allanjs is offline
post #195 of 239 (permalink) Old Jul 1st, 18, 10:39 AM Thread Starter
Keith
I bought a stencil. I used the stencil on the fenders. I had to redo the header though because the stencil was off by 1/8th.
I laid out the header by hand. I checked all dimensions against assembly manual measurements.
