Tim's 69 Grocery Getter - Page 12 - Team Camaro Tech
Build Projects follow along start to finish
 54Likes
post #166 of 230 (permalink) Old Jan 13th, 20, 02:32 PM Thread Starter
Tim
Re: Tim's 69 Grocery Getter
I just replaced a few of the photos with different settings so hopefully they show up. If not, my build thread may become retired.
1969 Camaro - a gift from the brother-in-law build thread
Shannon4570 is offline
post #167 of 230 (permalink) Old Jan 13th, 20, 03:03 PM
I can see the last four pics.
1959 El Camino project
1957 Buick Caballero project
dhutton is online now
post #168 of 230 (permalink) Old Jan 13th, 20, 03:05 PM Thread Starter
Tim
Originally Posted by dhutton View Post
For some reason I canít see the pics you just added.
Thanks for checking. Maybe I have it figured out.
post #169 of 230 (permalink) Old Jan 13th, 20, 04:47 PM
Tim, I can see your latest pics but nothing in post #157, 158 or 161.
my 67' build thread:
allanjs is offline
post #170 of 230 (permalink) Old Jan 13th, 20, 04:55 PM
Vega$69's Avatar
I see the 4 pics in Post # 161 no problem
Vega$69 is offline
post #171 of 230 (permalink) Old Jan 13th, 20, 06:46 PM Thread Starter
Tim
OK I think I have it fixed. I wasn't able to fix the previous posts (I think the time for editing had passed). So hopefully this will work going forward. Me typing with no pictures will be too boring to contemplate.
post #172 of 230 (permalink) Old Jan 13th, 20, 06:50 PM Thread Starter
Tim
On that note I guess I will add one more. Had to unwrap and start re-wrapping the relay harness as I need to have the wires pointed the opposite direction from how they were originally put together:
post #173 of 230 (permalink) Old Jan 13th, 20, 06:52 PM
Eric
Seeing the pictures you post has made me realize I need a new phone. Your images are fantastic!
1968 Standard Coupe, LS1, T56
2007 Tahoe, Z71, Cold Air & Tune
2001 Silverado, Z71, TSP Cam, Cold Air & Tune
really_n0b0dy is offline
post #174 of 230 (permalink) Old Jan 13th, 20, 07:02 PM Thread Starter
Tim
Thanks Eric, glad you enjoy them. I bought a iPhone XR this past summer and really like it. When I post larger pictures it's amazing to see the detail.
really_n0b0dy likes this.
post #175 of 230 (permalink) Old Jan 19th, 20, 10:59 AM Thread Starter
Tim
I think I may know the solution but I'm a little concerned. I noticed about a month ago the bottom of my oil filter on my crate engine had a drop of oil on it. I wiped it off so I could keep an eye on it and a new drop appears about once a week. I gave the filter an additional quarter turn to tighten it up but it didn't make much difference.
The picture makes it look like there is more oil than there really is - it's typically just a drop and appears to be originating directly above the QR code on the filter. I am thinking for whatever reason the gasket just has not seated well and I am the victim of seepage. Should I swap out the filter for another and see if it corrects the issue?
post #176 of 230 (permalink) Old Jan 19th, 20, 07:37 PM
Tim, Remove the filter and look for signs of the filter can contacting the casting so
as not allowing the filter gasket to actually seat (compress). Somewhere I read where
the gasket is thicker on a certain brand that I can't recall right now. Maybe Wix/Napa?
Also when you installed the filter did you spread a film of oil on the gasket? Common practice.
allanjs is offline
post #177 of 230 (permalink) Old Jan 19th, 20, 09:31 PM
Brett
The filter looks like it has a slight skew to it. In the photo, there are other features that are in the view that show the filter is not parallel. Optical illusion?
Brett.....
Rockets Up In 2020!
Brettallen59 is online now
post #178 of 230 (permalink) Old Jan 19th, 20, 09:32 PM Thread Starter
Tim
Thanks Al. I actually didn't install the filter and have done nothing more than tighten it a 1/8 or 1/4 turn. This is a crate engine that was dynoed before it came to me. I am sure it is something straightforward like you are describing but a little unnerving nonetheless on a brand new engine.
The engine was shipped with the run-in oil in it so thinking I can just swap out the filter without draining the oil and see if it corrects the problem.
post #179 of 230 (permalink) Old Jan 19th, 20, 10:08 PM Thread Starter
Tim
Brett.....
It doesn't look like it just looking at it (not the picture) but I think the easiest fix is to replace it and see what happens.
post #180 of 230 (permalink) Old Jan 20th, 20, 05:03 AM
I would check the oil block off plate above the filter. Seems more likely to weep oil imho.
