67 Ground-up Build - "Repro-Mod?" - Team Camaro Tech
Build Projects follow along start to finish
 9Likes
post #1 of 21 (permalink) Old Mar 10th, 19, 10:54 AM Thread Starter
Apprentice
I'm never sure what to call this project because it's an unusual (read: unnecessarily challenging) approach to building a first gen. In the words of a shop owner I know, "That's...ambitious."
I'm about 14 months into the project now and I'm a little late to be starting the build thread...I'll do the quick version to catch up. You may have noticed that there's two Camaros in the picture. I bought a rolling 67 last week to use for some measurements, then blast/prime/repair and replace sheet metal and sell.
I've always been jealous of the internal jigs that I see reproduction builders using so I'm going to get the 67 onto a jig cart and 3D scan the interior then CAD a modular jig that uses laser-cut brackets with bolts and alignment pins instead of welding. My project, to date, would've been 100x easier with this.
About the 68:
- 100% reproduction parts (AMD if available, Dynacorn for quarter-door subassemblies)
- DSE four-point roll cage with removable back bar
- DSE Quadralink
- DSE trunk closeouts and fuel pump access panel
- DSE subframe connectors
- Bowler T-56 transmission tunnel
- DSE lower link pocket reinforcements
- DSE mini tubs
- Smoothed firewall - just some sheet metal I bought and cut out
About the 67:
- Rust
- More rust
- Square body
- Also rust
But it's got good bones and that's all I need right now. Besides, maybe my wife will forget I'm supposed to sell it.
really_n0b0dy likes this.
bondwells is offline
post #2 of 21 (permalink) Old Mar 11th, 19, 03:12 PM Thread Starter
Apprentice
re: 67 Ground-up Build - "Repro-Mod?"
Just for fun, I decided to stick a GoPro in the garage and time-lapse the 67 restoration. Took the front end off it a few days ago and put it onto casters.
post #3 of 21 (permalink) Old Mar 11th, 19, 08:48 PM
Richard
Cool video! Thanks for sharing.
rebelbayou is offline
post #4 of 21 (permalink) Old Mar 11th, 19, 09:43 PM Thread Starter
Apprentice
Thanks! I'm not much for narrating but I thought it'd be cool to do a series of accelerated / time-lapse videos then string them all together at the end. If I had video of the 68 build to-date it would mostly consist of me staring at something scratching my head.
It's come a long way though.
Lately I've been doing a lot of cleanup stuff...welding drain holes, fixing fitment issues I've been avoiding, etc.
And the other side of course...
But I'm having some issues with the driver's side quarter that has me at a standstill, that's where the 67 comes in. I think I have it figured out but I really don't want to do it three times, twice is enough.
post #5 of 21 (permalink) Old Mar 11th, 19, 09:47 PM Thread Starter
Apprentice
I don't think my image tags worked properly but all the pics I was trying to share are here -> https://imgur.com/a/E6yGZWK
post #6 of 21 (permalink) Old Mar 12th, 19, 09:12 PM Thread Starter
Apprentice
Started cleaning up the deck lid today, I knew it was going to be rough. Still considering my options here. I think it's worth saving.
I think I may swing for the fences and try to weld in a patch and also get the skin off for better access.
Triman8654 likes this.
post #7 of 21 (permalink) Old Mar 13th, 19, 08:42 PM Thread Starter
Apprentice
Cut the deck lid apart to get after the damage and rust. Looks about as expected.
A little hammer and dolly work and it's looking a lot better but I'll probably end up patching it anyway.
The damage looks like someone backed into a tree but I couldn't find any corresponding damage to the rear end - and it would've been absolutely trashed for the deck lid to have been dented like that.
post #8 of 21 (permalink) Old Mar 20th, 19, 10:44 PM Thread Starter
Apprentice
Removed the LH outer cowl tonight to get after the hard-to-reach areas. Ended up deciding to cut off the lower 4" or so for easy access to the inside to bust through the spot welds - I couldn't get a good angle from the outside. Afterwards, I clamped the two pieces back in place, tack welded them together, then removed them to finish the butt weld and clean it up. It's probably going to get some minor patch work since the spot weld removal bit was a little more aggressive than I'd have preferred, but overall it's in pretty good shape.
Bonus points if you can spot me hitting myself in the forehead with my seam splitter @ 100x speed.
Last edited by bondwells; Mar 20th, 19 at 10:45 PM. Reason: Typo - "I've" changed to "I'd"
post #9 of 21 (permalink) Old Mar 21st, 19, 05:37 AM
Ben
you make it look so easy..lol
if i could do that repair in 2:28 minutes my car wouldv'e been 100% complete a long long time ago
bhodgdon400 is offline
post #10 of 21 (permalink) Old Mar 21st, 19, 05:38 AM
Ben
wish i could view the linked pictures of the 68. would love to see that process
post #11 of 21 (permalink) Old Mar 21st, 19, 03:10 PM Thread Starter
Apprentice
The best part about making a video 100x is you can't see all the frustration and dropped tools and tripping over myself...I also cut out about fifteen minutes of me trying to find my spot weld cutter.
I'm going to make a montage of the pictures I've taken of the 68 build to date. I have hundreds to sort through. I'll post a link in here when I'm done.
post #12 of 21 (permalink) Old Mar 22nd, 19, 11:11 PM Thread Starter
Apprentice
I managed to sort through about 1000 photos of the build-to-date on the 68 Camaro - montage here ->
bhodgdon400, RDW and Shannon4570 like this.
post #13 of 21 (permalink) Old Mar 23rd, 19, 07:04 AM
Ryan
WOW that is F...ing awesome. A lot of work but not rust repair. Looking forward to more.
Ryan.
YJ4000 is offline
post #14 of 21 (permalink) Old Mar 23rd, 19, 01:55 PM Thread Starter
Apprentice
Thanks Ryan. It's a different beast. Working on the 67 is a lot easier in many ways but rust is such a pain.
post #15 of 21 (permalink) Old Mar 23rd, 19, 02:52 PM
Great work. Especially with all that repop sheet metal.
1959 El Camino project
1957 Buick Caballero project
dhutton is offline
My 67 Resto Mod Build Sosh67 Build Projects 288 Nov 2nd, 19 01:56 PM
67 build pics stevo camaro Build Projects 11 Feb 17th, 19 08:54 PM
'67 Coupe Ground Up / Rotisserie Resto --1st-Gen Collection Complete! 6781camaro Build Projects 15 Sep 17th, 18 09:27 AM
