Thoughts on my future build? - Team Camaro Tech
Build Projects follow along start to finish
 3Likes
  • 1 Post By Vega
  • 1 Post By ilikeike
  • 1 Post By dhutton
post #1 of 8 (permalink) Old Feb 5th, 20, 05:11 AM Thread Starter
donnie
I just bought a super straight clean rust free 67 Camaro coupe orig a/c car, my plans run from dropping a 250 straight 6 with vintage air and being different.
To using a stock 4 bolt main gm 350 to the beast zz502 all backed by a Muncie 4 speed, the car will be driven a lot with stock 15x6 disc brake rally's and redline tires.
Id appreciate all the guys and gals inputs here are a few paint combos I'm looking at and the car as it sits now floor and trunk are perfect
dads67z is offline
post #2 of 8 (permalink) Old Feb 5th, 20, 05:13 AM Thread Starter
donnie
Re: Thoughts on my future build?
as it sits now....
dads67z is offline
post #3 of 8 (permalink) Old Feb 5th, 20, 05:51 AM
Vega$69's Avatar
Whatever you decide go with an OD tranny.
502 HP ZZ502 is NOT good bang for the buck at over $10K
I would go LS and forget the 60 year old tech
If you don't like LS then think about a 500 hp 400 SBC for under $6k
https://blueprintengines.com/product...tor-bp4002ctc1
bhodgdon400 likes this.
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #4 of 8 (permalink) Old Feb 5th, 20, 05:57 AM
shawn
x2
frog7151 is online now
post #5 of 8 (permalink) Old Feb 5th, 20, 06:26 AM
Darin
ilikeike's Avatar
Modern transmission for sure. But whatever your vision is, is how you should do it.
Id' prefer an LS/LT based engine, maybe dressed or disguised to look like a carbureted engine,move the coils off the valve covers.
Or a BIG" small block with lots of aluminum on it to lighten it up.
Some cars look good parked on the grass,but drive like a wet noodle.
some cars are much more fun to drive than just park and look at.
I'd like one that does both well if I could afford it.
Depends on what you enjoy and how much $$ you can blow.
yellow69RS likes this.
1968 Butternut Coupe,
421" Dart SHP block
TKO 600 RR
Dutchman 9" w/3.70
Global West arms
Budnik wheels
ilikeike is offline
post #6 of 8 (permalink) Old Feb 5th, 20, 06:52 AM
15x6 wheels and a ZZ502. Entertaining combo....
1959 El Camino project
1957 Buick Caballero project
dhutton is online now
post #7 of 8 (permalink) Old Feb 5th, 20, 05:30 PM
Jeff
yellow69RS's Avatar
And redline tires. I realize they are available as radials but I always envision them as bias ply.
Jeff
yellow69RS is offline
post #8 of 8 (permalink) Old Feb 6th, 20, 03:45 AM
Greg
pittpens24's Avatar
Would definitely go with a 5 or 6 speed trans. Add 4:11 gearing and a moderately built 350 or LS for a really fun car. Tire and wheel upgrades would be a must!
'68 Camaro with RS conversion
Moser 9" with 4:11
Tremec T-56 Magnum 6 speed
572 BB - CM Engines
pittpens24 is offline
