67-68 led stop/brake/turn setup cheap - Team Camaro Tech
Tips & Tricks Member submited how-to's
post #1 of 29 (permalink) Old Aug 20th, 11, 07:03 AM Thread Starter
Kevin
SixtyAte's Avatar
OK,
I found some LED lights that others are selling for $129.99 a pair and that is for standard only. If you wanted to do a RS car, double that amount. I spent some time searching and found a site that lists the LED kit complete for a 67 RS at $49.99 a side! A 67 or 68 standard would be $21.99 a side for the stop/turn and the backup for $37.99 each. I bought four of the 68 Stop/Turn lights, and cut one to fit within my tail housings. Looks perfect and works super too. No wire cutting, the screw into your old sockets and the wires get tucked into the housing like a bulb did before. I will post pictures later but wanted to get this out !
Kev
http://www.speedwaymotors.com/1968-C...hts,38426.html
ID:	24121   Click image for larger version
ID:	24122   Click image for larger version
ID:	24128   Click image for larger version
ID:	24129   Click image for larger version
SixtyAte is offline
post #2 of 29 (permalink) Old Aug 20th, 11, 07:22 AM
Re: 67-68 led stop/brake/turn setup cheap
Sound/look simular to what I have in mine (but I cut the plug and hardwired). I got mine through a vendor here (Mike Redpath) and love them....super bright day or nite No reason someone couldn"t see you
68 Camaro~LSx ~all motor
post #3 of 29 (permalink) Old Aug 20th, 11, 07:53 AM
Jerry R.
jr68's Avatar
Thanks Kev
I'm in
my Magnaflow X-pipe system sound clip, click the link
jr68 is offline
post #4 of 29 (permalink) Old Aug 20th, 11, 05:45 PM Thread Starter
Kevin
SixtyAte's Avatar
I added pics to show what they look like with parking lights on and with the running and brakes on. Left to right pics are..
Running Lights Overall
Running LIghts Close
Brake LIghts/Running Lights Overall
Brake LIghts/Running Lights Close
Doug,
I wanted to be able to go back without having to cut/splice wiring if the need arises
Kev
ID:	24132   Click image for larger version
ID:	24133   Click image for larger version
SixtyAte is offline
post #5 of 29 (permalink) Old Aug 27th, 11, 08:28 AM
Panhead57's Avatar
Do they make any for the 69 Camaro?
____________
69 Z28, X-77, Hugger Orange, DZ302, 4.10 Posi
Panhead57 is offline
post #6 of 29 (permalink) Old Aug 27th, 11, 08:34 AM
Mike Redpath
Musclerodz & Customz
405-735-8405
pro-touring parts specialists
www.musclerodz.com
post #7 of 29 (permalink) Old Sep 23rd, 11, 06:09 AM Thread Starter
Kevin
SixtyAte's Avatar
Did anybody here try these lights? I think they are great and have got compliments on the brightness and looks!
Kev
SixtyAte is offline
post #8 of 29 (permalink) Old Sep 28th, 11, 07:46 AM
prostreet69camaro's Avatar
Did you have to add the electronic flasher for the blinkers and flashers to work.
I did not use this setup, 69 camaro, but the 2 sets I used I had to add the electronic flasher. The cheapest place to buy the flasher was Spaghetti Engineering.
http://www.digi-tails.com/Electronic-LED-Flasher/
prostreet69camaro is offline
post #9 of 29 (permalink) Old Sep 28th, 11, 08:29 AM Thread Starter
Kevin
SixtyAte's Avatar
Mike,
These do not require any special flashers at all. They work great with the stock flashers.
Kev
SixtyAte is offline
post #10 of 29 (permalink) Old Sep 28th, 11, 09:56 AM
Russ
Dang those are bright, aren't you worried about the cops being able to better see you leaving the scene ?
Russ (RJ)
The Garlic Capital, Gilroy,CA
(sold June 15,2014) 1968 RS convertible that is not quite stock
rj68RS is offline
post #11 of 29 (permalink) Old Sep 28th, 11, 02:07 PM Thread Starter
Kevin
SixtyAte's Avatar
Too Funny...
I carry a badge
Kev
SixtyAte is offline
post #12 of 29 (permalink) Old Oct 2nd, 11, 07:30 PM
Jerry R.
jr68's Avatar
Kev
I put mine in yesterday morning, it took like 20 minutes. I can't believe how easy they went in and they are way brighter than the originals. I went on a 40 mile cruise with about 300 cars and good brake lights were just what the doctor ordered. Thanks for putting me onto these Kev.
jr68 is offline
post #13 of 29 (permalink) Old Oct 2nd, 11, 08:12 PM
Bill
Calpantera's Avatar
I did not see the reverse lights for standard '67 on that site.
Calpantera is offline
post #14 of 29 (permalink) Old Oct 2nd, 11, 08:16 PM
Bill
Calpantera's Avatar
OK I found the reverse lights under '68, same lens size I assume?
post #15 of 29 (permalink) Old Oct 3rd, 11, 04:26 AM Thread Starter
Kevin
SixtyAte's Avatar
Jerry...
Glad to have helped. The brightness is amazing ! Easy install and easy on the pocket too
Kev
SixtyAte is offline
