Emissions Removal??? 97 RS 3800 - Team Camaro Tech
Tips & Tricks Member submited how-to's
post #1 of 3 (permalink) Old Dec 15th, 12, 12:49 PM Thread Starter
Andy
I would like any and all the info I can get to remove as mush Emissions junk that I can from my 97 RS 3.8. I just pick this up for the wife It was not running and was not all together. It has headers, no cats, dual exhaust with H pipe and cold air intake, What Emissions can GO/
shivey1 is offline
post #2 of 3 (permalink) Old Dec 15th, 12, 02:18 PM
Vintage 68's Avatar
Re: Emissions Removal??? 97 RS 3800
I hope you take reply correctly and no offense intended ...
If you're asking this question and don't thoroughly understand the systems that control the engine functions - whether they effect 'smog' or not - yore doomed to just end up with terrible running/driving non-smog vehicle
Almost any post-90s vehicle has electronic control of most timing, AFR and other operational systems for engine performance.
These post A.I.R./smog-pump engine designs use engineered combustion controls vs. added crud you could just unbolt and throw away.
There really is no valid reason to remove modern OEM 'smog' parts to improve performance unless you can program around that device and improve combustion efficiency.
Removal of a given part will most likely effect other systems, failure to engineer around this just destroys the operation of the engine.
Reducing intake restriction and improving exhaust flow can be positive efficiency and performance upgrades.
Anything beyond that requires a well thought out and engineered plan.
We can always address specific questions if you have them about any of the given systems and parts.
As always JMHO
1968 Convertible
Some trucks
Vintage 68 is offline
post #3 of 3 (permalink) Old Dec 15th, 12, 05:26 PM Thread Starter
Andy
Thanks John and no offense taken.
My concern is that the old owner removed the stock exhaust and installed headers and they removed the Linear EGR Valve, What is this going to effect and can it be bypassed with out big problems?? And there are a few vacuum line missing and I'm looking for info or a good picture to reference but I'm striking out. Any help would be great.
shivey1 is offline
