Broken Bolt Removal Tip - Team Camaro Tech
Tips & Tricks Member submited how-to's
post #1 of 14 (permalink) Old Dec 18th, 12, 05:23 PM Thread Starter
Bob
I had three exhaust manifold bolts snapped flush with the heads on the LS I picked up. I tried Easyouts, which didn't work. Someone had suggested welding a nut to the end of the boolt, but I couldn't get a good weld down in the hole after several tries, so the nuts didn't hold.
Instead, I welded a washer to the end of the bolt, and then welded a bolt to the washer. The broken bolts turned out effortlessly. This was made easier since the heads are aluminum, which prevented the washer from bonding to the head, but a thin layer of grease on the bottom of the washer could probably solve that concern on a cast iron head.
Unfortunately, I forgot to take pics, but I think you get the idea.
BobKovacs is offline
post #2 of 14 (permalink) Old Dec 18th, 12, 05:32 PM
Vintage 68's Avatar
Cool Re: Broken Bolt Removal Tip
The combination of localized heat on the fastener and the increased perch of a nut really makes removing broken-off or frozen fasteners much easier
If you trying to get a bolt out without welding, the use of a "Left-handed" drill bit will yield great results.
I bet 90% of the time the piece starts to back out on the drill bit before it ever hits the bottom for me
1968 Convertible
Some trucks
Vintage 68 is offline
post #3 of 14 (permalink) Old Dec 18th, 12, 06:54 PM
Vega$69's Avatar
So no new heads for you.
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #4 of 14 (permalink) Old Dec 18th, 12, 07:23 PM Thread Starter
Bob
Nope- was a bit saddened about that myself, but in the end, I'll still get the hp I'm looking for even without them, and will have about $1,500 to spend on the rest of the project.
post #5 of 14 (permalink) Old Dec 18th, 12, 07:42 PM
Vintage 68's Avatar
Talking Re: Broken Bolt Removal Tip
Originally Posted by BobKovacs View Post
Nope ...
... and will have about $1,500 to spend on the rest of the project.
You'll burn through that in a heartbeat with just mounts, exhaust and driveline mods
1968 Convertible
Some trucks
post #6 of 14 (permalink) Old Dec 19th, 12, 02:02 AM Thread Starter
Bob
Already accounted for that....
post #7 of 14 (permalink) Old Dec 19th, 12, 07:12 AM
Vega$69's Avatar
I got a guy that will do a great mild port and polish for a very good price.
69 Z28(Sold)
(SOLD)
Vega$69 is offline
post #8 of 14 (permalink) Old Apr 21st, 13, 06:49 PM
Pat
Nice tip! I've been welding nuts on forever. I've usually pulled it off with a small stick welder instead of the wire welder. This tip should make it even easier.
PatDTN is offline
post #9 of 14 (permalink) Old Aug 4th, 13, 04:35 AM
igra
sorry for my english a bolt means a hexagonal nut right,if so i saw a mechanic when a bolt was broken from both ends he hmm used a scratcher make its shape identical to a nut then very carefully opened it.hope it adds a new idea in your heads.
thanks for reading
igrapablov is offline
post #10 of 14 (permalink) Old Aug 4th, 13, 08:18 AM
Pat
thanks for reading
Filing the bolt end into a hex head could work. If you can get to it. You can also cut across with a hacksaw to make a slot for a screwdriver. Both methods require a bolt to be sticking up from the metal. Not very likely for most bolts.
Still, one more way to get a broken bolt out.
PatDTN is offline
post #11 of 14 (permalink) Old Aug 6th, 13, 10:12 AM
I just went through this yesterday on my 1998 Dakota p/u. Two ex bolts were broken, about 1/8" in the hole and really tough to access with a mig welder. I contemplated trying it anyway, but was afraid I'd just weld the stud to the cast iron head. Long story short, KROIL,left handed drill bits and easy-outs didn't work. Ended up drilling them completely, and retapped the holes to 3/8-16 and used grade 8 studs. They were originally wimpy 8mmx1.5.
BPOS is offline
post #12 of 14 (permalink) Old Aug 6th, 13, 10:14 AM
Pat
Yeah, times like that a 1/16 stick welder is handy. The flux helps keep you from welding to the sides as you get yourself started. As long as the bigger studs fit through the head you're probably better off now.
PatDTN is offline
post #13 of 14 (permalink) Old Aug 6th, 13, 10:25 AM
I did have to enlarge the holes in the ex manifold, but cast iron drills like butter.
If I was smart, I'da drilled the others and done the same, but I'm not smart. The 3/8 studs are much bigger than the 8mm bolts I replaced.
BPOS is offline
post #14 of 14 (permalink) Old Aug 6th, 13, 10:28 AM
Pat
LOL! Somewhere in the middle of my reply I started thinking you had replaced a head bolt not an exhaust manifold bolt. D'Oh!
PatDTN is offline
