blowout welding - Team Camaro Tech
Tips & Tricks Member submited how-to's
post #1 of 15 (permalink) Old Sep 26th, 13, 03:03 PM Thread Starter
Kenny
blowout welding
Why am I blowing a bigger hole than I'm trying to fill when I'm welding. I haven't started welding any pieces on yet but I'm plug welding some holes where I drilled out spot welds. Its not doing it every time but more than not. I'm using a Lincoln 140 mig welder and my settings are on A the lowest setting and my wire speed is at 3 to 4. I've tried adjusting every way I can but I get the same results. I might add I'm new to welding but I have been practicing. Oh and I am using Argon/CO2 and its set at about 22 l/min.
WTH?
Kenny Gentry is offline
post #2 of 15 (permalink) Old Sep 26th, 13, 04:07 PM
Re: blowout welding
Kenny, You're probably not moving the stinger fast enough. Start in the center of the hole and move outward in a circular manner. All surfaces need to be ground or sanded clean prior to welding. Also use the smallest diameter wire available for your welder. Clamp pieces tightly together. No substitute for practice/experience. Here's a You Tube video that might be helpful.
my 67' build thread:
allanjs is online now
post #3 of 15 (permalink) Old Sep 26th, 13, 04:21 PM Thread Starter
Kenny
Re: blowout welding
Thanks Al that will help when I start welding panels on, I'm filling in holes now where there is nothing behind what I'm welding, just the hole. Do my settings look ok.
post #4 of 15 (permalink) Old Sep 26th, 13, 04:41 PM
Re: blowout welding
Kenny, You need to backup the hole with a piece of copper. Do a Google search for welding spoon.
post #5 of 15 (permalink) Old Sep 26th, 13, 05:35 PM Thread Starter
Kenny
Re: blowout welding
Thanks again Al , I looked on weldingtipsandtricks.com and it was very helpful and I think I may have had my gas set a little high so I turned it down a little and tried welding on a piece of scrap metal and I had a much better weld. One more question if you don't mind, what's the best way to grind my welds down and prep for prime. Oh yeah and I thumbed thru your build thread and your work looks great and you've come a long way on your car. Can't wait to get mine going in that direction
post #6 of 15 (permalink) Old Sep 26th, 13, 07:00 PM
Re: blowout welding
The best method for grinding I have used came from Scott (Sauron67MM). Use a wide cutoff wheel on a cutoff air tool to grind the weld down close to the finished surface. Then use a Roloc style grinding disc (varying grits) on a right angle air tool to finish blending the weld. Take a look through this thread to get an idea of what a finished weld can (should) look like. Scott has posted many tips on welding and other topics.
https://www.camaros.net/forums/showthread.php?t=212160
post #7 of 15 (permalink) Old Sep 28th, 13, 01:02 PM
Re: blowout welding
Kenny, Here is a link to a thread at Garage Journal describing the grinding method (with good pics) I was referring to. Look for the posts by MP&C. Robert is very good at working sheet metal and emphasizes the need for tight gaps on butt welds when possible. Info I'm sure you will find helpful as you progress with your build.
http://www.garagejournal.com/forum/s...ad.php?t=53534
post #8 of 15 (permalink) Old Oct 3rd, 13, 03:49 AM Thread Starter
Kenny
Re: blowout welding
Wow, he's good
post #9 of 15 (permalink) Old Oct 30th, 13, 10:49 PM
Josh
Re: blowout welding
Whats your wire size? If your using .035 or .030... Thats your problem. Use .023 for thin gauge such as 16, 18, 20 etc. Also you can fill it without a copper thing or whatever whats his face said. It just takes practice, just tack it until its filled. Tack the hole like your looking at a clock on the wall.
First tack it at 9 o clock let cool then tack at 3 o clock let cool tack at 12 o clock let cool tack at 6 o clock let cool etc etc etc see the pattern your tacking. Your spreading the heat in different sections so that just one spot doesn't get so hot you burn a hole in it.
Hope this helps Cheers
Just a Fabricator
OFF GRID ENGINEERING, LLC
mason7674 is offline
post #10 of 15 (permalink) Old Oct 31st, 13, 02:43 AM
Re: blowout welding
Sheetmetal welding usually requires multiple trigger pulls also. Little 2-3 second pulls works better than trying to fill it all at once....depending on size hole.
Also look up rosette weld (just another slug/plug/spot weld name)
68 Camaro~LSx ~all motor
post #11 of 15 (permalink) Old Nov 2nd, 13, 05:19 AM Thread Starter
Kenny
Re: blowout welding
Thanks guys, I think one of my problems was the welder I was using. I bought a Lincoln 140 from Lowes which only has A,B,C and D heat settings and I couldn't fine tune it for lighter gauge metal. Well after a few weeks of burning holes in metal practicing welding I finally went to my local AIRGAS welding supply for help and info. The guy there told me I needed one with infinite settings so I could control the heat better and my welds would improve. Anyway I returned the 140 to Lowes and bought the 140C from AIRGAS which was $100 more and I'm getting much better results now.
Josh, thanks for the info., I'll try that technique when I get a chance to get back out to the garage. I checked out your Fabrication work on your FB page and I'll say that's some of the best looking welding I've ever seen. You do some excellent work for such young man and with skills like that you have a bright future ahead of you. Keep up the good work.
Doug, thanks for your help too, I've never heard it called a rosette weld but I googled it and found some helpful tips. I am going to get out to the garage this weekend sometime and practice my welding. Thanks again guys.
'67 RS Black on Red originally and again some day.
L48 350 from a '67 SS going in some day too
post #12 of 15 (permalink) Old Nov 27th, 13, 12:44 PM
Bill
Re: blowout welding
Congratulations. It looks like you've resolved your problem. For others with the same problem that cant get a different welder, I agree with Al above, back up the hole with a piece of copper.
arocars is offline
post #13 of 15 (permalink) Old Dec 5th, 13, 03:41 PM
James
Re: blowout welding
also realize that as the distance between your wire and work piece increases the amperage goes up in order to jump the gap and will cause blow outs.
James
"Collectin' Camaro's since only Rednecks Drove them"
firstgenaddict is offline
post #14 of 15 (permalink) Old Dec 5th, 13, 04:05 PM
DEREK
DEROID's Avatar
Re: blowout welding
Suggestion guys that worked for me take a piece of 3/4 in copper pipe cut a slit in it length wise then hammer the cut pice flat. Free welding spoon!!!
DEROID is offline
post #15 of 15 (permalink) Old Dec 5th, 13, 07:15 PM
Sean
Re: blowout welding
I saw that your gas setting was at 22lph, and you said that you turned it down. I run mine between 8-12 depending on what i am working on and never have a problem with splatter. Also, if you are having trouble with a hole blowing out, instead of trying to fill the hole initially, weld a circle around the hole on the outside where the metal has not been drilled or thinned. This way, you will have a thicker piece of metal to fill against, and you are going to grind it off anyhow. It is what i do when i have to weld up metal that has been rusted and thinned.
1967 RS/SS Camaro 383 5 speed tremec 3.70
1967 RS/SS Camaro 383 5 speed tremec 4.10
1967 RS Camaro Convertible 327 4 speed 3.73
1969 SS Camaro 6.0 LS Twin Turbo 5 Speed 3.50
2013 ZL1 Camaro roto-fab airbox pulley swap Rest In Pieces March 27 2014
FTF Automotive is offline
