'67 subframe tear down help - Team Camaro Tech
Tips & Tricks Member submited how-to's
post #1 of 10 (permalink) Old Nov 3rd, 13, 08:24 AM Thread Starter
Kenny
Hey guys, what's the best way to take the upper and lower control arms off without the coil spring flying off and hurting anyone or damaging anything. I know it needs work but I think I want to use my original instead of an aftermarket.
ID:	51073   Click image for larger version
ID:	51081   Click image for larger version
'67 RS Black on Red originally and again some day.
L48 350 from a '67 SS going in some day too
Kenny Gentry is offline
post #2 of 10 (permalink) Old Nov 3rd, 13, 09:41 AM
Re: '67 subframe tear down help
BEEEEEEEEEEEEEEEEE CAREFUL ! speaking from personal experience ..IT CAN HURT YOU !
I actually used a rod ...9 1/6 or 5/8 ( AS BIG AS WILL FIT IN THE SHOCK HOLE ) with a plate on each end - runs thru the SHOCK HOLE ON THE A ARMS.. I USED HEAVY GRADE 8 nuts on each end and once i poped the ball joint ,I REMOVED THE TOP A ARM FIRST by lifting it up and over the rod then i backed off the nut to release the preassure and slowly lower the lower a arm till there is no preassure. worked great ...
i use the same method when installing the new springs...
its in-expensive and u can get it at the hardware store.
If your not going to use the springs again ( which im guessing your not ) you can heat the springs with a torch to relax them first - takes some of the preassure off. ( if you have a torch ...
the make a spring colaps tool but , the one i had let loose and thats how i got hurt..
hugger1 is offline
post #3 of 10 (permalink) Old Nov 3rd, 13, 09:41 AM
paul
I wrapped a cargo strap around the spring and tied it tight. then undid the bottom ball joint nut and split the hub away from the balljoint. then released the cargo strap.
all went ok. to replace I will make a spring compressor.
paulmanta is offline
post #4 of 10 (permalink) Old Nov 3rd, 13, 09:48 AM
kevin
I don't figure you will reuse the springs, I would just take a torch to them
flat tire is offline
post #5 of 10 (permalink) Old Nov 3rd, 13, 11:05 AM
I seen it done with a chain as well...but as Hug points out, you got a lot of tension to work with, and if it gets away from ya!
Some places will rent a spring compressor. And as mentioned for the price why not just torch and replace?
capt
captcanuck68 is offline
post #6 of 10 (permalink) Old Nov 3rd, 13, 05:52 PM
Kenny, there are countless threads in the suspension forum how to do this using a quality spring compressor. Many, including myself know how to remove and install springs without them, and on uninstalled bare subframes. But you may choose to take the secure route.
Sauron67MM is online now
post #7 of 10 (permalink) Old Nov 3rd, 13, 06:44 PM
Gordon
gordr's Avatar
Basically take the shocks out and wind a reasonably thick chain thru the spring and "tie" it to the frame using nuts and bolts in the holes in the chain....leave just a little slack in the chain. Then you can do basically what you want, have someone sit on the upper A-arm when you pop it to keep weight on it and then he gets off and you're done. Then pop the lower ball joint to complete the job.
67 Plain Jane being assembled with 427, 4 spd Muncie, 12 bolt rear with Mosers, 4 wheel discs
gordr is offline
post #8 of 10 (permalink) Old Feb 24th, 15, 01:51 PM
charlie
Best advice I can give is using the cargo strap. Wrap it though the spring and when your ready to remove it let a little slack out of it. It will keep the spring from flying across your garage as well
fishybudguy is offline
post #9 of 10 (permalink) Old Feb 25th, 15, 10:11 AM
I recently removed my springs on a bare subframe. I ran a cargo strap through the spring and around the frame just in case it springs. I got a spring compressor from Autozone from their loan a tool program. Compress the spring and pop the ball joint. Use a cargo strap or a chain for safety though.
'67 SS/RS 350, Muncie M20, Black with black interior.
b17brian is offline
post #10 of 10 (permalink) Old Mar 4th, 15, 03:00 PM
jared
I took mine out and put back in new springs with a bare sub frame just like you. It was a pain. But luckily I have a big piece of rod recessed in the floor for pulling dozer tracks on and off . I used that to hold the frame down while I took the ball joint loose. I used a jack under the lower a arm.
jcfcamaro is offline
