Tip For Tightening Header Bolts - Team Camaro Tech
Tips & Tricks Member submited how-to's
post #1 of 8 (permalink) Old Jul 14th, 14, 02:49 PM Thread Starter
I got tired of seeing "Wheel Dollies" here every time I log on
A deep offset box wrench is pretty handy for tightening header bolts. Usually longer than a standard box wrench of the same size for more leverage - esp when a 3/8 header bolt has a 3/8 head vs the standard 9/16 and hence a much shorter wrench. Plus it will often fit where a socket won't. That's it
https://www.google.com/search?site=i...Teo&gws_rd=ssl
BPOS is offline
post #2 of 8 (permalink) Old Jul 14th, 14, 05:00 PM
Re: Tip For Tightening Header Bolts
I even used socket head screws/bolts before...worked pretty decent too
depends on tube size...
68 Camaro~LSx ~all motor
post #3 of 8 (permalink) Old Jul 14th, 14, 06:05 PM
Brent
67Rally's Avatar
Question Re: Tip For Tightening Header Bolts
With the old 350 (before the LS swap) I had a cheap deep offset box wrench that I took to a grinding wheel. I took about half the thickness of the metal off and it made it much easier to tighten the bolts without dinging the headers.
Not rubbing it in, but with the way the LS headers are designed and the hex head bolts I have, I can reach everything with ease. I can also remove all the spark plugs in about 5 minutes or less.
67Rally is offline
post #4 of 8 (permalink) Old Jul 14th, 14, 06:10 PM
Vega$69's Avatar
These are handy too. Use them with the ARP Header Bolts
Attachment 79050
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #5 of 8 (permalink) Old Jul 14th, 14, 08:13 PM
scblucam's Avatar
This deserves a story. Back in the day "I know everybody hates that" My bud Mike had a 69 GTO 400ci and was putting headers on. As we all know, you need a special "header wrench" to finish the task. After trying to saw through a hardened wrench forever we watched him sitting "Indian Style"(can I say that?)in the driveway taking a hammer and chisel to it to make a shorter wrench. Ever smacked your ankle with a hammer? From that position I never would have imagined someone could jump that high. We LOAO. Mike was not impressed.
68 302 M20 - 85 IROC Z
scblucam is offline
post #6 of 8 (permalink) Old Jul 15th, 14, 03:34 AM
Steiner
Best tool I've found so far for header bolts is Dynatechs. First ones I've ever been able to get a socket on the back bolts, and that's with a 1-3/4" tube. I've got a set of 5/16" head bolts in a drawer somewhere that would let me get a socket on all of them but with the 3/8" ones now it's already so easy compared to the past that it's not worth the time to change them out. Plus I haven't had to touch them in thousands of miles since the install and retorque with Percy's gaskets.
'69 Camaro
500hp/538lbft
Steiner is offline
post #7 of 8 (permalink) Old Jul 15th, 14, 04:10 AM
Good point, Steiner-
I use Percy's dead soft gaskets and have yet to see a header bolt loosen up.
Sent from my iPhone using Autoguide
Melrose RS is offline
post #8 of 8 (permalink) Old Aug 3rd, 14, 03:13 PM
Bill
"I got tired of seeing "Wheel Dollies" here every time I log on." ... Hilarious!
arocars is offline
