Battery Terminal Cleaner - Team Camaro Tech
Tips & Tricks Member submited how-to's
post #1 of 9 (permalink) Old Oct 15th, 14, 06:53 PM Thread Starter
If you happen to have a 1/2" copper fitting in the wall of your house to an outside hose bib that froze and split last winter and spewed water for several hours while you were gone....
...one of those cheapie battery terminal cleaners works good for prepping the pipe end as well as the inside of the fittings for soldering.
http://crazyniko.com/images/battery_doc/21000.jpg
BPOS is offline
post #2 of 9 (permalink) Old Oct 16th, 14, 08:58 AM
Vintage 68's Avatar
Talking Re: Battery Terminal Cleaner
Y-e-a-h ... well, except for all that acid and lead residue that's usually on older battery tools
Good suggestion I guess, if you went out a bought a new one for doing it ... but, I think I'll stick with my Oatey copper pipe tools for plumbing work
1968 Convertible
Some trucks
Vintage 68 is offline
post #3 of 9 (permalink) Old Oct 18th, 14, 08:22 AM
Jeff
yellow69RS's Avatar
Not sure why you think this is a problem..... You are probably fluxing you stuff with acid anyway and if you plumbing is over 10 years old there's probably lead solder in the joints already. As for my place the supply line from the B-Box in is lead.
If I needed something in a hurry I'd do this.
Jeff
yellow69RS is offline
post #4 of 9 (permalink) Old Oct 18th, 14, 08:26 AM
Even sandpaper or a scotchbrite works for either
But, yes, I wouldn't use one for both. Contamination "could be" an issue....better safe than sorry
I mean...unless you're in a pinch and middle of the nite.
68 Camaro~LSx ~all motor
post #5 of 9 (permalink) Old Oct 18th, 14, 02:51 PM
I think Al is suggesting a 'new dedicated' terminal cleaner.
Not a used one.
post #6 of 9 (permalink) Old Oct 18th, 14, 05:05 PM Thread Starter
Precautions duly noted
This was for an outside hose bib - primary purpose is occasionally hosing dog **** off my shoes after a mow (dog owners'll know what I mean)
FYI - the terminal cleaner was new. They're about a buck each @ HF when on sale.
BPOS is offline
post #7 of 9 (permalink) Old Dec 18th, 14, 02:20 PM
Bill
A (new) battery terminal cleaning tool is what I use for cleaning copper pipes before soldering. Works great.
arocars is offline
post #8 of 9 (permalink) Old Dec 19th, 14, 05:59 AM
Those Depot etc copper pipe cleaners are junk. They don't last. If I didn't use a piece of sand paper to sweat pipes, I'd use this idea and keep the terminal cleaner in my kit. Great idea if all you're doing is 1/2" fittings.
'69 SS396 X66 L34 08D (8/22/1969) M21 BS
460ci Gen VI 9.75:1
Semper Fi!
HawkX66 is offline
post #9 of 9 (permalink) Old Dec 19th, 14, 06:05 AM
George
Gbauer's Avatar
In that case the acid might be an added feature to help clean your shoes...
Sold:
Offy intake
Holley 390 CFM carb
Mild cam
Custom interior
Gbauer is offline
