Front Spoiler/Air Dam Outer Supports/Braces Breakaway Mounts. - Team Camaro Tech
Tips & Tricks Member submited how-to's
post #1 of 22 (permalink) Old Mar 14th, 15, 03:58 PM Thread Starter
Lightbulb Front Spoiler/Air Dam Outer Supports/Braces Breakaway Mounts.
I know there are plenty of 1st generation enthusiasts that don't like to run the front spoiler or air dam outer supports/braces due to the potential damage that could be done to the lower section of the front fender(s) where they attach if there is ever an impact of some type such as bumping a curb. But there are also those that would like to run them for the original/factory installed look without running this risk. I think I may have come up with a solution.
Years ago I was very active in flying radio controlled model airplanes and volunteered as an instructor two evenings a week. The training planes that new modelers would learn to fly with usually had the wing held on by either #64 rubber bands or nylon screws/bolts. I witnessed the nylon screws/bolts act as a fuse over and over again in hard landings and even crashes where the nylon screws/bolts would shear off saving much damage to the rest of the model airplane. So I ordered some 1/4" x 20 nylon screws and replaced the steel bolts on both ends of my front spoiler/air dam outer braces, I kept the rest of the existing hardware (washers & nuts) as nothing is really gained by swapping them to nylon. I'm hoping I never find out how well they work as a fuse, but either way, thought I'd pass the idea along for any others that might be interested in doing the same.
NH69Z28RS is offline
post #2 of 22 (permalink) Old Mar 14th, 15, 04:11 PM
Jonathon
Smitty68's Avatar
Re: Front Spoiler/Air Dam Outer Supports/Braces Breakaway Mounts.
Pretty neat idea Scott. Are you running any of the braces? I set my brother in laws car up with only the center brace. I know that most won't go with it like that. But keeping the front end intact is more of a concern for me than it being correct with all the braces. Thanks for the post and keep us posted on hopefully not any bad news as to how it works out..
68 Resto-Mod in progress..355sbc .350 Trans Rushforth wheels
My Build:
Smitty68 is offline
post #3 of 22 (permalink) Old Mar 14th, 15, 04:34 PM
Gary
69Z28-RS's Avatar
I like that idea as well... does that nylon retain 'cast blast paint' very well?
Gary
69Z28-RS
Corvettes (5), Nomads (2), El Camino, etc
69Z28-RS is offline
post #4 of 22 (permalink) Old Mar 14th, 15, 04:42 PM
Phil
Have you done the wind speed / wind resistance, shear calculation? I'd be glad to "field test" this for you if the math is too difficult.
Phil
Full Car Media Blasting:
69TAPoser is offline
post #5 of 22 (permalink) Old Mar 14th, 15, 05:25 PM
Tim
Good idea. Did you swap the nylon at the fender extension end of the outer braces?
1969 04A Van Nuys-built Z/28. Cortez Silver with dark blue interior and VE3. Sold Clippinger Chevrolet. Raced at Lions in LA.
ZLP955 is offline
post #6 of 22 (permalink) Old Mar 14th, 15, 05:30 PM Thread Starter
For the last three seasons only the outer braces were there with metal hardware, I just added the center brace with metal hardware but changed the outer brace bolts to nylon screws at both ends of the supports/braces.
post #7 of 22 (permalink) Old Mar 14th, 15, 05:32 PM Thread Starter
I didn't paint mine, but I'd think prepping them with some lacquer thinner they would hold paint fairly well. They are available in black nylon at better hobby shops that carry a good supply of R/C model airplane parts.
post #8 of 22 (permalink) Old Mar 14th, 15, 05:34 PM Thread Starter
Phil
The wind/speed test will take place later this season, I could use a second vehicle riding alongside to watch if/at what speed the nylon bolts shear. You game Phil
post #9 of 22 (permalink) Old Mar 14th, 15, 05:35 PM Thread Starter
Yes, I changed the outer brace bolts to nylon screws at both ends of the supports/braces so four nylon screws total (twice as likely to shear if needed that way).
post #10 of 22 (permalink) Old Mar 14th, 15, 05:43 PM
Jonathon
Smitty68's Avatar
I think with your idea and just have the center brace with metal hardware. At least "if" you hit a big possum or any other medium sized rodent your chances would be somewhat better without the side braces and your hardware it should work.
My Build:
Smitty68 is offline
post #11 of 22 (permalink) Old Mar 14th, 15, 05:49 PM
Phil
I will make sure my rear view mirror is installed by then.
Phil
post #12 of 22 (permalink) Old Mar 14th, 15, 05:52 PM
Jonathon
Smitty68's Avatar
Originally Posted by 69taposer View Post
i will make sure my rear view mirror is installed by then.
Phil
:d
My Build:
Smitty68 is offline
post #13 of 22 (permalink) Old Mar 14th, 15, 06:41 PM
Tim
Only reason i asked is because I would've thought that the weaker nylon screw at one end only would be more likely to shear, only one weak point in the brace connections. Hmmm.
ZLP955 is offline
post #14 of 22 (permalink) Old Mar 14th, 15, 06:53 PM Thread Starter
Phil
Sounds as if you are making assumptions based on wishful thinking with no supporting facts having yet been offered as/into evidence?
With that in mind, install the rear view mirror(s) if you like, but make sure your windshield is nice and clean so you can see me to you through my rear view window
post #15 of 22 (permalink) Old Mar 14th, 15, 06:54 PM
Jerry
Great Idea.
69 SS/RS
565 BBC
Tremic 6 speed
Dragonfly Jones is offline
