spark plug removal - Team Camaro Tech
Tips & Tricks Member submited how-to's
post #1 of 17 (permalink) Old May 26th, 15, 04:52 PM Thread Starter
kevin
spark plug removal
68 Camaro, 383 raised port pro comp angle plug heads 1 3/4" hooker super comps
does anyone have any tricks on how to remove and install the plugs for #3 and #5 cylinder
every thing I have is either to long to short or to big in diameter
flat tire is offline
post #2 of 17 (permalink) Old May 26th, 15, 04:56 PM
Camarodude67
Re: spark plug removal
I usually use a closed ended wrench.
camarodude67 is offline
post #3 of 17 (permalink) Old May 26th, 15, 05:19 PM Thread Starter
kevin
with the angle of the plug and the steering box there is no way to use a box or open wrench.
I can get a thin wall socket with a short universal on the plug , but I can only move it about 3 turns . then I can't get my combination of the plug . so then I have to tighten back about two turns to get everything off. then it is a hex headed plug socket and move it maybe 1/8' at a time
it takes me 1.5 hours to remove #3 and #5 plug. the same or a little more time for replacement
post #4 of 17 (permalink) Old May 26th, 15, 05:50 PM
ZZ_430's Avatar
Break it loose the way you have been doing, and then slip a section of tight-fitting vacuum tubing on the end of the plug and turn it out.
Don ~ TC Member #15 ~
Don't mess with Texas!
ZZ_430 is offline
post #5 of 17 (permalink) Old May 26th, 15, 06:42 PM
X2 I use 3/8 fuel hose. Makes a great universal for spark plugs
BPOS is offline
post #6 of 17 (permalink) Old May 26th, 15, 06:49 PM
Vega$69's Avatar
Another thought is to use shorty spark plugs
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #7 of 17 (permalink) Old May 26th, 15, 10:20 PM
Steps
Yep used to have that issue.
Buy a chinese elcheapo set of sockets and ring spanners.u can mod the plug socket to drop over the plug... to break loose...use a bent modded ring spanner....
Once the torque is broken the plug winds out with fingers nps.
u may also find access is easier with the wheel turned or even off the car...
And next time do not put cold spark plugs into a warm engine... cold plugs cold engine.
Steptoe is offline
post #8 of 17 (permalink) Old May 27th, 15, 03:22 AM Thread Starter
kevin
thanks for the replies
I have tried all the above . I guess I was hoping to hear of something I hadn't tried
if photobucket was working properly I would post a picture of the altered tools and different lengths of hose I have
post #9 of 17 (permalink) Old May 27th, 15, 03:43 AM
Yes, had the same problem years ago.
Get a hex head plug socket and shorten the height - yes, insulator will stick out of the sq drive. Use wrench to loosen/tighten.
As said by Steps, once loose, fingers, or as others suggest, and I have one in my tool box, a length of fuel line and vacuum hose for slipping over the insulator and screw/unscrew the plug.
post #10 of 17 (permalink) Old May 27th, 15, 05:13 AM
Vega$69's Avatar
http://buy1.snapon.com/catalog/item....roup_ID=674849
This works for lots of hard to get to plugs
69 Z28(Sold)
(SOLD)
Vega$69 is offline
post #11 of 17 (permalink) Old May 27th, 15, 06:44 AM
Darin
ilikeike's Avatar
That doesn't sound like too much fun.
I have the same headers for my sbc, and haven't purchased the heads yet, I'll make sure to get straight plugs heads, but I'm sure it will still be a PITA.
1968 Butternut Coupe,
421" Dart SHP block
TKO 600 RR
Dutchman 9" w/3.70 US Gear Lightning r&p
Global West arms
Budnik wheels
ilikeike is offline
post #12 of 17 (permalink) Old May 27th, 15, 07:33 AM
That's what I have also. Works great on hard to get to plugs.
'69 SS396 X66 L34 08D (8/22/1969) M21 BS
460ci Gen VI 9.75:1
Semper Fi!
HawkX66 is offline
post #13 of 17 (permalink) Old May 27th, 15, 07:41 AM Thread Starter
kevin
I went and bought a cheap 3/8" drive 5/8" plug socket a 7/32" 1/4" drive socket and several 1/4" extensions
my plan is to weld the 7/32 to the 3/8 which should give me room to use the 1/4 ratchet
I hope
post #14 of 17 (permalink) Old May 27th, 15, 09:19 AM Thread Starter
kevin
just to let you know the setup in the above post worked great. I did forget to take the rubber out of the plug socket before welding, but that actually made it easier to get the socket on
one other thing I did was to take a cutoff wheel to the male end of the extension behind the square and it gives you a wobble affect
post #15 of 17 (permalink) Old May 27th, 15, 02:16 PM
Steps
If u dial in a engine well, and considering the quality of modern spark plugs... its not often one needs to change them anyway.
Camaro service due yesterday.. change oil, grease, radiator drain and flush, top up washer bottle, check timing curves, VA curves/ diaphram vac specs etc... And fortunately my wife has an incredible 'ear' for engines... describes what hears in a manner one can "ID" the issue.. she picked up a slight miss between 1200 and 1600 rpms taking off from an intersection taking the car to her work couple days ago.
So time to change spark plugs... take them out.. look good, very good actually...very little wear on some to hardly any on others...
Check the car log... damn 10 1/2 yrs since they where put in !!!!
NGK BP6S (slightly colder plug for the high octane fuel)
Keep in mind this is a daily driven car for the last 35 yrs...
Dial your engine in has huge benefits besides performance economy... but reliability, maintenance, and convenience.
And yes she was right on about the miss.. the data logger O2 richen up 4 points
Steptoe is offline
