Argon/CO2 use - Team Camaro Tech
Tips & Tricks Member submited how-to's
post #1 of 4 (permalink) Old Apr 21st, 16, 11:07 AM Thread Starter
Jerry
Argon/CO2 use
Hello folks,
Can anyone tell me how long a 40 CF Argon/CO2 bottle will last, assuming a constant lit mig torch(knowing the stinger will not be lit constantly).Maybe 1 hr or several hours?
In other words is a 40 CF bottle worth purchasing. I'm a novice welder and only use my welder on rare occasions around the garage and maybe building work stands etc.
Thanks for any input
Jerry
Hot 67 is offline
post #2 of 4 (permalink) Old Apr 22nd, 16, 08:43 AM
Jeff
yellow69RS's Avatar
Re: Argon/CO2 use
I use a twenty and a 40. I always seem to start a project on Friday night when I run out which puts me waiting until Monday to refill. Depending on your regulator setting the time that last varies. I think I set my regulator to about 7 CFH so the 20 lasts me just less than 3 hours of actual gas flow. I seem to go in streaks, I'll weld alot for a few days then nothing for months. That might be a contributing factor to always running out at the start of a new project.
Jeff
yellow69RS is online now
post #3 of 4 (permalink) Old Apr 22nd, 16, 09:30 AM
Darin
ilikeike's Avatar
Re: Argon/CO2 use
We have the 40 at work just incase we run out. I've used the 40 at home building some shelves before,it lasted two weekends worth of welding,so maybe 2~3 hrs of welding.(I run 15 cfh or so)
I bought an 80 for my home garage,good size for home projects. I paid just under $200 for the used bottle about $40 to fill with 75/25. I wouldn't buy a 40 unless it was real cheap,like free. get an 80 min.
1968 Butternut Coupe,
421" Dart SHP block
TKO 600 RR
Dutchman 9" w/3.70 US Gear Lightning r&p
Global West arms
Budnik wheels
ilikeike is offline
post #4 of 4 (permalink) Old Apr 22nd, 16, 10:17 AM Thread Starter
Jerry
Re: Argon/CO2 use
Thanks for the info guys. Seems like the 40 CF bottle will be fine for my use
Hot 67 is offline
