what rearend - Team Camaro Tech
Tips & Tricks Member submited how-to's
post #1 of 2 (permalink) Old Mar 17th, 17, 01:43 PM Thread Starter
Guy
what rearend
what about the car is a 1980 camaro berlinetta with 273 gears and a 450hp 383 stroker and a turbo 350 with extra clutches and a shift kit , I have a 373 pos track that i want to use what do you think about it all
fastGuy is offline
post #2 of 2 (permalink) Old Mar 17th, 17, 02:00 PM
Re: what rearend
A 1980 Camaro has an 8.5 inch ten bolt with leaf springs that is the same as most of all of the previous rear ends under Camaros. If you have a 2.73 it will accept a 3.73 gear, but you will have to upgrade the differential to an Eaton three series Posi-Trac to limit wheel spin. You can also buy one that uses 30 spline axles instead of the stock 28 spline axles you have now to add strength.
You say you have one but are you sure it works with your existing rear end. In 1982 the third generation Camaro was introduced that used a 7.5 inch rear gear with coil springs and a torsion tube-trailing arm suspension. So I question is what you bought used to fix your problem.
Big Dave
Larger Dave is offline
Tags
rearend383stroker450 hp
