Welding help - Team Camaro Tech
Tips & Tricks Member submited how-to's
 4Likes
  • 1 Post By DT
  • 1 Post By dhutton
  • 2 Post By stamatisg1977
post #1 of 13 (permalink) Old Jun 18th, 17, 09:35 AM Thread Starter
Steven
stamatisg1977's Avatar
Welding help
I have a hobart handler 190
Im using .024 wire and using gas
My issue is thatbi keep blowin holes in the sheetmetal
My settings are as follows
Wire speed - 30
Amperage setting - 1
Is this because of the chinese metal?
Any advice or tips are greatly appreciated
stamatisg1977 is online now
post #2 of 13 (permalink) Old Jun 18th, 17, 09:41 AM
Daryl
1968RallySport's Avatar
Re: Welding help
Look at your settings chart that came with your welder. You need to know the gauge of the sheet metal. Here's a link to a chart for your welder: https://www.hobartwelders.com/produc...ochart187.html
1968 Rally Sport
302ci
Muncie M22
Moser 12-bolt 4:10 posi
1968RallySport is offline
post #3 of 13 (permalink) Old Jun 18th, 17, 09:43 AM
Kevin
KevinW's Avatar
Re: Welding help
Use a copper plate as backing.
Kevin
KevinW is offline
post #4 of 13 (permalink) Old Jun 18th, 17, 09:47 AM
DT
Donny
DT's Avatar
Re: Welding help
Wire speed - 30
What does the chart recommend for the gauge of sheet metal you are attempting to weld ? (on the inside door of your welder) Are you attempting a Butt weld ??
1968RallySport likes this.
DT is online now
post #5 of 13 (permalink) Old Jun 18th, 17, 09:57 AM
Tony
Re: Welding help
Clean all surfaces to bare metal (both sides of sheet metal) Use an inert gas, Back off with lead if you need to. move in circular motion after weld penetrates...
Tony
Follow my current Camaro project builds...
1967 Coupe (Sold)
1968 Convertible
1969 Convertible
bondora68 is offline
post #6 of 13 (permalink) Old Jun 18th, 17, 10:05 AM Thread Starter
Steven
Recommended setting for the gage im welding is actually
40 wire speed
And 2 on amperage
So im actually lower in power and still burning thru
I cant get anything behind what im welding and metal is properly ground and cleaned with my ground as close as possible to work area.
post #7 of 13 (permalink) Old Jun 18th, 17, 10:18 AM
DT
Donny
DT's Avatar
Re: Welding help
40 wire speed
And 2 on amperage
You didn't mention if your attempting a Butt weld, Lap weld etc ??? Butt welds will burn through easily if you have a big gap.
DT is online now
post #8 of 13 (permalink) Old Jun 18th, 17, 10:22 AM
Re: Welding help
Turn up the wire speed and use shorter pulses of the trigger. Try 50 on the wirespeed and 1 on the current. That will reduce heat. Are you trying to weld some rusty metal or is it all new metal? Make sure your metal is clean.
Pics would be useful.
1959 El Camino project
1957 Buick Caballero project
dhutton is online now
post #9 of 13 (permalink) Old Jun 18th, 17, 11:47 AM Thread Starter
Steven
Butt welds mostly
It happens when i welded the trunk corners and front edge of the hood.
Also happens when welding rod to fenders for gaps. Altho pics dont show breakthru. They are what im generally talking about
Just want to inow for future welding
Happy fathers day to all!!
ID:	185898   Click image for larger version
post #10 of 13 (permalink) Old Jun 18th, 17, 03:27 PM
Re: Welding help
Try feeding the wire faster with a shorter pulse of the trigger. Less heat that way.
post #11 of 13 (permalink) Old Jun 18th, 17, 03:57 PM Thread Starter
Steven
Will do thank you
post #12 of 13 (permalink) Old Jun 19th, 17, 10:27 PM Thread Starter
Steven
Thanks for all the advice
I turned up the wire speed to around 55
And kept amperage at 1
And did short bursts and i had no blow throughs while i plugged up un needed holes in the firewall
dhutton and bondora68 like this.
post #13 of 13 (permalink) Old Jun 20th, 17, 05:32 AM
Gary
MangeMD's Avatar
Re: Welding help
I found that if you try to weld at a 90 degree angle you'll blow holes as well. Dropping the angle and short pulses fixed it for me.
1967 RS Coupe (clone): 406 SBC, Thorley headers, Muncie, Hotchkis suspension, Centerline Matrix 17" wheels with Nitto 555's, Baer brakes, 12 bolt 3.73 posi, RS conversion, Vintage Air, PPG Hot Red. (SOLD)
1968 RS Coupe: Project...Mini-tubbed, Cammed LS 6.0, T56, 12 bolt 3.73 posi, Ridetech 4 link...slowly adding more...
MangeMD is offline
