Cleaning a Radio and Removing Static - Team Camaro Tech
Tips & Tricks Member submited how-to's
post #1 of 4 (permalink) Old Mar 29th, 18, 09:22 PM Thread Starter
Wayne
I didn't find anything on our site about cleaning radios but I did discover some information about cleaning electronic equipment and also getting rid of static when you turn the knobs on our old radios. I bought a 69 am/fm radio and took it to an electronics repairman and had him check it out. It sounded okay but there was static when you turned the volume or the tuner. He told me I could clean it and it would probably get rid of the problem if the parts weren't worn out. He said they get dirty and dry. He said Deoxit D5 or other equivalent electronics cleaner and lube would work. So I took the screws off of the top plate and moved it out of the way. Then I used compressed air and blew out the dirt and dust. I lightly sprayed the Deoxit on the tuner and volume control parts as well as on the push button mechanisms. Now it plays with no static and the buttons move the dial very easily. It's all seems to work like new now. I also replaced the 1893 lamp while I was at it.
BUT, A WARNING. Do not ever spray this or any other brand of cleaner on any electronics and turn it on immediately. It could cause an explosion and/or catch fire. It's in the directions and the repairman warned me. If it's in the car you should disconnect the battery and wait a couple of hours or more for the vapor part of the spray to fade away before you connect power or turn on the radio or whatever electronic appliance you've worked on. Thought this might help someone someday.
1969 Z11
69ndpce is offline
post #2 of 4 (permalink) Old Mar 29th, 18, 09:33 PM
scblucam's Avatar
Re: Cleaning a Radio and Removing Static
Maybe this should have first. Spray ,check, boom, oops.
68 302 M20 - 85 IROC Z
scblucam is online now
post #3 of 4 (permalink) Old Mar 30th, 18, 02:22 AM
Kevin
KevinW's Avatar
I have used Deoxit on old home stereos with great success. works well!
Kevin
KevinW is offline
post #4 of 4 (permalink) Old Mar 30th, 18, 05:08 AM
Good tip given.
