This little light of mine. ... - Team Camaro Tech
Tips & Tricks Member submited how-to's
 6Likes
  • 1 Post By HawkX66
  • 1 Post By 68Tiger
  • 1 Post By HawkX66
  • 1 Post By scblucam
  • 1 Post By 67sc
  • 1 Post By HawkX66
post #1 of 14 (permalink) Old Sep 24th, 19, 03:38 PM Thread Starter
stan
Any tips or tricks to clean up a Edelbrock intake without removing it,.....
BOOGIES is offline
post #2 of 14 (permalink) Old Sep 24th, 19, 03:59 PM
kevin
Re: This little light of mine. ...
brushes and carb cleaner
flat tire is online now
post #3 of 14 (permalink) Old Sep 24th, 19, 11:37 PM Thread Starter
stan
Tried carb cleaner,alumabrite, Mothers wheel cleaner ,just can't get it looking new again, really don't want to remove it just to bead blast it,....
BOOGIES is offline
post #4 of 14 (permalink) Old Sep 25th, 19, 03:23 AM
kevin
try a mild acid type wheel cleaner designed for open cut wheels. such as Eagle One Etching MAG Wheel Cleaner
if you do decide to pull it and clean it, get cerakote placed on it.
all you need then is a damp rag to clean it
post #5 of 14 (permalink) Old Sep 25th, 19, 07:08 AM
You'll spend a hell of a lot more time screwing around with it only to mess up everything around it. If you're that concerned about its aesthetics, spend the five minutes to pull it off and the 1/2 hour if your struggling to put it back on.
68Tiger likes this.
'69 SS396 X66 L34 08D M21 BS
460ci Gen VI 9.75:1 AED 950 carb
Semper Fi!
HawkX66 is offline
post #6 of 14 (permalink) Old Sep 25th, 19, 09:14 AM
Brandon
Aluminum ceramic engine paint.
Brandon J. licence 1NASTY67
Nantooch is online now
post #7 of 14 (permalink) Old Sep 26th, 19, 06:51 PM
Dom
68Tiger's Avatar
I tried everything to clean my Edelbrock Performer RPM Intake manifold with no luck! After much contemplating I finally decided to pull it, Bead blast or Jet Hot it. At the last minute I weighed time spent and cost to refurbish it vs cost of new including three coats of clear high temp satin paint and decided to just bite the bullet and replace it with a new one. Ether way Refurbished or New it had to be removed, cylinder head surfaces cleaned, gaskets replaced, new SS bolts and put back on so that part is a wash. For what it's worth I think I made the right call. I'm very pleased with the outcome. BTW now my tarnished Alternator is driving me crazy! Only a matter of time before I replace that too!
Name:	Old Intake Manifold 2019.jpg
ID:	229509   Click image for larger version
Name:	Intake Manifold New 2019 3.jpg
ID:	229513   Click image for larger version
Name:	Intake Manifold New 2019 4.jpg
HawkX66 likes this.
1969 Camaro RS, 327ci, TH350 Automatic, Richmond 3:55 12 Bolt Posi, Norwood 11C build date. Recipient of December 2017 Team Camaro ROTM.
68Tiger is offline
post #8 of 14 (permalink) Old Sep 26th, 19, 07:06 PM
bob
I had good luck using Eastwood aluminum cleaner.
https://www.eastwood.com/ew-aluminum...er-bottle.html
bob15 is online now
post #9 of 14 (permalink) Old Sep 27th, 19, 06:08 AM
I wish I could have helped you tackle this while I lived by you. I would have thrown your intake in my blast cabinet and whala, brandy new looking. I threw a coat of paint on mine after I did it so it wouldn't tarnish and it's held up well. Your results came out great.
68Tiger likes this.
Semper Fi!
HawkX66 is offline
post #10 of 14 (permalink) Old Sep 27th, 19, 02:54 PM
Dom
68Tiger's Avatar
Thanks Dave! I sure could have used your expertise and knowledge. I still might have it Bead blasted and then just stash it away? You can never have too many spare parts.
68Tiger is offline
post #11 of 14 (permalink) Old Sep 27th, 19, 06:01 PM
scblucam's Avatar
I cleared mine when it was new. Yellowed slightly but been on since 1985.
68Tiger likes this.
68 302 M20 - 85 IROC Z
scblucam is online now
post #12 of 14 (permalink) Old Oct 2nd, 19, 11:19 PM
Kev
I had one blasted and it doesn't look like new. I'm sure they coat them w/ something when new. I cleared it but still not quite right. Oh well.
Just FYI
68Tiger likes this.
67sc is offline
post #13 of 14 (permalink) Old Oct 3rd, 19, 06:23 AM
Frank
https://www.napaonline.com/en/p/MCR1458
'68 Camaro 454, 4sp
Just 1 More is offline
post #14 of 14 (permalink) Old Oct 3rd, 19, 08:14 AM
Just FYI
Having it "blasted" is a pretty subjective term. There are a whole lot of factors that can change the way it comes out. Look how Lloyd (EdgemontVillage) uses his Vapor Blaster. Amazing results. What I used in my media blast cabinet made mine look like new also. I just chose to paint it.
68Tiger likes this.
Semper Fi!
HawkX66 is offline
