1976 International Scout II - Team Camaro Tech
Non-Camaro Tech Problems and Issues with your daily driver or other non-Camaro vehicles.
post #1 of 18 (permalink) Old Oct 27th, 11, 12:48 PM Thread Starter
Kalif Johnson
Send a message via AIM to dreamweaver
I just picked it up a couple of weeks ago to play around with.... have an electrical "issue":
A. The reverse lights don't work at all
B. When you put the turn signal on the brake lights go out
C. The brake indicator light on the instrument panel is always on
Don't know if they;re interrelated, or separate issue or interrelated.
Also, the speedometer measures about 20 mph over actual speed, and it bounces around quite a bit.
Dana 44 locker in the rear, 427 gears (not original gears, but original housing)
Any ideas?
"The masses have never thirsted after truth. They turn aside from evidence that is not to their taste, preferring to deify error, if error seduce them. Whoever can supply them with illusions is easily their master; whoever attempts to destroy their illusions is always their victim." - Gustave Le Bon
dreamweaver is offline
post #2 of 18 (permalink) Old Oct 27th, 11, 04:49 PM
Jay
Re: 1976 International Scout II
Maybe as simple as replacing brake light bulbs..
purecam is offline
post #3 of 18 (permalink) Old Oct 27th, 11, 05:15 PM
Kevin
I have a buddy that was huge into scouts while I was into the jeep thing. The last one he had that I helped him with had similar issues with the electrical, in his case it was a lot of corrosion affecting grounds and in some cases the light sockets. I would start there on the electrical, the speedo jumping sounds like its gummed up inside or frayed. Try running cleaner (wd40) or something similar through it til it runs clean then run some light weight oil into it and let it soak for a couple days if its just gummed up it should cure it.
Kevin.
My 68's resurrection thread
Shandara is offline
post #4 of 18 (permalink) Old Oct 27th, 11, 06:17 PM Thread Starter
Kalif Johnson
First thing I checked ... bulbs are good.
Kevin.
Yeah - I read somewhere that one thing I could do is find all the grounds and replace the sontact screws with stainless ones...
I'll check the sockets on the lights.
I'll try the WD-40 / oil thingie
post #5 of 18 (permalink) Old Oct 27th, 11, 07:49 PM
K.P. Walsh
dont worry, if a scout does'nt have elecrical issues somethings wrong.
kevin p...................
1972.5 Camaro!
Z27LS3 is offline
post #6 of 18 (permalink) Old Oct 27th, 11, 07:59 PM
67 Camaros Rock
Joe Harrison's Avatar
Just cut up some old extenshion cords and you will have repro wiring for it. That 20 MPH thing is a factory option to make you think a Scout was actaully quicker that it really was.....the bouncing is to keep you busy while it just lumbers down the road with 392 sucking down about 10 gallons per hour while the leaky rear mail seal and cap keep the chassis lubricated and the floor pans rust free.
I actually like Scouts!!! I have had few Scout Traveler II's.
-Mark Donahue
My 67 Camaro Time Line
Joe Harrison is offline
post #7 of 18 (permalink) Old Oct 28th, 11, 06:08 AM Thread Starter
Kalif Johnson
That made my day, and it's only 6:00 a.m. --- And it only has a 345, so I get a remarkable 8 gallons an hour
post #8 of 18 (permalink) Old Oct 28th, 11, 06:49 AM
r_w
Robert
My Dad had 3 of those over the years for land surveying, with the right tires you can climb right up a tree.
If the back window glass doesn't go "squeaky squeaky squeaky squeak" as you drive down the road something is broken.
______________
Life is too short to drive cars that suck.
'67 Convertible
r_w is offline
post #9 of 18 (permalink) Old Oct 28th, 11, 07:08 AM Thread Starter
Kalif Johnson
It's got 33's on it right now... wonder if that has anything to do with the speedo (in addition to the bounce on the gauge), reading about 20 mph higher than it really is???
No hard top... only a soft top:
post #10 of 18 (permalink) Old Oct 28th, 11, 08:35 AM
Different speedo gears needed for tire & gear given, unless you go back to stock tire size and OE 3.54's.
Speedo needle bouncing could be a kinked speedo cable.
post #11 of 18 (permalink) Old Oct 28th, 11, 08:59 AM
I like it! Nice beach truck.
Melrose RS is offline
post #12 of 18 (permalink) Old Oct 28th, 11, 10:51 AM Thread Starter
Kalif Johnson
It would be good for that, if I had a beach
Mostly will be used as:
A. A vehicle for my daughter to go back and forth with
B. Something to take her fishing with
C. Something to pull my forklift our of my lawn the next time I get it stuck in the winter (Yes, I think I have pics )
post #13 of 18 (permalink) Old Oct 28th, 11, 11:21 AM
67 Camaros Rock
From where to where....the end of the block and back? Unless she is independently wealthy and can afford the gas for that beast she can go around the block once or twice on a tank. I love scouts but man they suck the gas down like collage kids hitting beer bongs at a frat party.
-Mark Donahue
post #14 of 18 (permalink) Old Oct 28th, 11, 11:32 AM Thread Starter
Kalif Johnson
It's only for her to go back and forth to school with.. only about 5 miles each way, so it should be less than a grand a month
The rest of the time it will just be what it is... a toy.
post #15 of 18 (permalink) Old Oct 28th, 11, 12:00 PM
67 Camaros Rock
Let her know that 4 wheel low lock is.....she can pull into any parking spot she wants.....in the instance that another car is already there she can just pull in and park on top of it. No parking problems for her and those things are tanks, she should be safe from small cars that will just bounce off of it like pin balls.
-Mark Donahue
