Heater fan does not run all the time - Team Camaro Tech
Non-Camaro Tech Problems and Issues with your daily driver or other non-Camaro vehicles.
post #1 of 3 (permalink) Old Dec 11th, 11, 03:11 PM Thread Starter
I have a 2000 Blazer. The heater fan does not run all the time and when it begins to run, it will run until the vehical is shut off. Sometimes it will run when you restate the vehical but not all the time. The controls check out ok. The heater warms the car and the defroster also works fine. I am beginning to think it is the vacuum system, but I have no clue where to start. Any ideas?
Thanks,
hotrodgasket is offline
post #2 of 3 (permalink) Old Dec 11th, 11, 04:07 PM
Re: Heater fan does not run all the time
John, There is most likely a resistor in the system that has gone bad. Most
are located behind the glove box. You will have to remove the glove box to
get at it. It's a fairly common Chevy truck thing.
my 67' build thread:
allanjs is offline
post #3 of 3 (permalink) Old Jan 3rd, 12, 06:27 PM
ern
ern
the motor itself might be bad ,next time it wont go just give it a tap with you hand if it starts it is in the motor
ern is offline
