any good GM mechanics,need help with 97 Tahoe - Team Camaro Tech
Non-Camaro Tech Problems and Issues with your daily driver or other non-Camaro vehicles.
post #1 of 8 (permalink) Old Dec 19th, 11, 12:59 PM Thread Starter
richard
z28rich's Avatar
Question any good GM mechanics,need help with 97 Tahoe
My buddy has a 97 Tahoe with a 5.7 vortec all stock with about 80,000 miles.its been running fine and then one day he gos to start it ,it runs really rough.then it pops a code of P0300 which is random misfire.so why would it run great then run like crap a few days latter he pulled the plugs and they look good.now what
1969 Garnet Red Z/28-RS with Black stripes
and Black Deluxe Int. I found my build sheet
2012 Shelby SVTPP GT500 race red with dash signed by Caroll Shelby
RIP Mr Shelby
z28rich is offline
post #2 of 8 (permalink) Old Dec 19th, 11, 01:23 PM
kt
kelly
Re: any good GM mechanics,need help with 97 Tahoe
If all the basic tune up stuff is fresh, including plug wires etc. Also check compression i bet its good but its easy to check. I would then check fuel pressure and compare it to spec. a few psi below spec will make a difference, i think its 55-62 psi, koeo with pump running.
kt is offline
post #3 of 8 (permalink) Old Dec 20th, 11, 08:16 AM
Guy
the intake is part plastic and the injectors are inside. i had problems starting, sometimes it would start and sometimes it would not. fuel pump goes bad and makes it run bad.
jl8z28 is offline
post #4 of 8 (permalink) Old Dec 20th, 11, 08:32 AM
Tony B
Id look at the coil pack. I think 97 was the last year of the optispark. Those go out, and make it run rough...
Your vehicle details go here
69Z28/SS396 is offline
post #5 of 8 (permalink) Old Dec 20th, 11, 01:11 PM
Rich
no OPTI on vortec 350 but does have special cap, rotor and wires - you need to be careful replacing the cap - you can damage the base of distibutor (its plastic) and this stuff isnt cheap. like stated above check the fuel system in the intake- I'm not sure if they had "popets" vs injectors - the 6 cyl vortecs had alot of issues with them-not sure with the v-8s - hope this helps! these motors are also known for intake gaskets suddenly failing and causing o/heating- the gaskets are plastic with silicone seals
69 R/S Z/28 302 X33 D80 late 09C
69 T/A clonification LS6-6speed under construction
15 ZL1
64 Chevelle wagon 6.0l planned sons toy
zman1969 is offline
post #6 of 8 (permalink) Old Dec 20th, 11, 04:16 PM
george
With 80k on the clock..the poppets would benefit from an injector flush.
A proper flush..not an in tank additive.I have had great results with the BG injector clean solution.You will need to do this thru the fuel rail service port and require the remote pressure tank.Most shops will have this equipment and typically cleans up random misfires on the R engine.
George
68 Camaro
8-71 blown 461 Rat on E-85
fatblock is offline
post #7 of 8 (permalink) Old Dec 20th, 11, 10:03 PM Thread Starter
richard
z28rich's Avatar
why would it run good and run like **** a few days latter?
RIP Mr Shelby
z28rich is offline
post #8 of 8 (permalink) Old Jan 6th, 12, 05:17 PM
Alex Folino
Send a message via AIM to AlexFolino
What is your fuel pressure reading? Ive worked on so many of these(dealer) that if i had a dollar for everytime id be able to retire..
GM service technician.
25 years old. I only drive chevys. Everything else and i do mean everything can rust in piece.
68 owner-The only way to go
Camaro: A small vicious animal that eats mustangs.
AlexFolino is offline
