My 97 Tahoe puked the radiator - Team Camaro Tech
Non-Camaro Tech Problems and Issues with your daily driver or other non-Camaro vehicles.
post #1 of 7 (permalink) Old Jan 21st, 12, 12:44 PM Thread Starter
click's Avatar
On the way to movie last night with the Mrs... temp guage pegged to the right (HOT) and light came on 'check guages' duh... I had just pulled into parking lot, so let it sit while in the movie, figured maybe a stuck thermostat. On way home, temp guage ran normal, heat coming in, it was -8 degrees.
This morning on way to breakfast with son in law, again, temp guage pegged to right (HOT) as we pulled into Perkins and right then, blewie...steam rolling from under hood. Shut down and after steam cleared, looked like the drivers side radiator hose, on top next to windshield 'add' resevoir, blowing antifreeze all over. Not sure if its the hose or cracked radiator. Had it towed to my mechanic, he will get at it on Monday. Ive never had a thermostat lock up but there was no heat in the car and engine overheating, so my guess is the 'stat'. Anyone else ever go thru this? grrrr cold weather.
Anti freeze was full a week ago when I checked all fluids, oil normal full.
The movie was GREAT, loved it, will buy the DVD when it comes out.
click is offline
post #2 of 7 (permalink) Old Jan 21st, 12, 01:39 PM
Casey
Re: My 97 Tahoe puked the radiator
Dang the bad luck, Click! Keep us posted on what it is. Sounds like what you think it is, though. The sides of the radiator are plastic and they do come undone, unfortunately. I even had one swell up in one area. I'll say this...I would not get an after-market radiator if I planned on keeping it.
I posted here about a possible intake water leak on my '99 Suburban, and it turned out to be a leak--they're famous for it. I talked to the service rep at GM, and he suggested I use these tablets with new antifreeze . I put 2 in my radiator and I'm good to go. The rep said that these tablets will seal the cooling system, including the intake.
After you get either your hose or radiator fixed, you may want to use these cooling system seal tabs.
Good judgment comes from experience; and experience, well, that comes from bad judgment. - Anonymous
casey0272 is offline
post #3 of 7 (permalink) Old Jan 22nd, 12, 02:54 PM
richard
z28rich's Avatar
check your intake for leaks,if you havent done it.you will.
1969 Garnet Red Z/28-RS with Black stripes
and Black Deluxe Int. I found my build sheet
2012 Shelby SVTPP GT500 race red with dash signed by Caroll Shelby
RIP Mr Shelby
z28rich is offline
post #4 of 7 (permalink) Old Jan 22nd, 12, 06:31 PM
changing out a radiator in one of those trucks takes about a half hour and requires like 4 tools..
you don't plan sincerity.
novaderrik is offline
post #5 of 7 (permalink) Old Jan 23rd, 12, 06:25 AM Thread Starter
click's Avatar
I hear ya derrik but with no heated garage it wont be done here by me. If it was spring or summer, Id tackle it for sure. Had the intake gasket redone about 2 years ago, oil has been good on the dipstick so pretty sure its not that again, sure hope not. Will find out when he calls with the report sometime today.
click is offline
post #6 of 7 (permalink) Old Jan 23rd, 12, 07:41 AM
jason
67-CAM-RIDER's Avatar
Same thing happened this week to my 97 Tahoe. Same place, next to the driver's side washer bottle. 175,000 miles in the Texas heat. Had to replace the radiator and hoses,
67 Camaro
67-CAM-RIDER is offline
post #7 of 7 (permalink) Old Jan 23rd, 12, 08:57 PM Thread Starter
click's Avatar
new radiator, new upper and lower hoses, plastic valve up near firewall that controls heat into the cab was cracked and leaking as well. Old radiator had 2 cracks in plastic housing, one on each side near top outlet...
Total cost $582. oh well, 160,000 miles on it and still runs good.
click is offline
