82 350 - Team Camaro Tech
Non-Camaro Tech Problems and Issues with your daily driver or other non-Camaro vehicles.
post #1 of 10 (permalink) Old Jan 27th, 12, 04:44 PM Thread Starter
corey
82 350
Hey guys how are ya ? I just need your opinions, I have a 350 in a 82 cutlass , its a stock rebuilt bottom end with a come 270H-10 comp cam 70cc edelbrock aluminum heads, specs are intake runner 185cc exhaust runner 60cc intake diameter is 2.02 and exhaust diameter is 1.60, comp roller rockers performer intake , msd street fire dissy and a 670 cfm holley street advenger carb, has 150 psi per cylinder for compression. I was just wondering if thoses heads are a right choice for the engine or if I should of went with something else, I will be getting 410 gears and posi here soon so that should help over the stock gears, and is my compression ratio around 8;1 ? and with that set up what do you guys think a ball park HP would be for the engine? I know its a lot of questions but I would like to find out what you guys think .
thanks all in advance
steps350 is offline
post #2 of 10 (permalink) Old Jan 27th, 12, 07:18 PM Thread Starter
corey
Re: 82 350
anyone?
steps350 is offline
post #3 of 10 (permalink) Old Jan 27th, 12, 07:39 PM
Michael Gekko
Re: 82 350
corey, I don't recall the exact specs on that cam, years ago a friend had one in a 305 iirc.
I would guess around 320 HP , and I think the compression is around 8.5 or 8.75 . IMO those heads are a pretty good choice for what you have. Might be a touch on the large side, might be something to grow into as time goes on.
Eleanor's Nemesis is offline
post #4 of 10 (permalink) Old Jan 27th, 12, 08:56 PM Thread Starter
corey
Re: 82 350
ya I like the heads I just wanted some one elses opinion, people around here told me to to swap thoes heads out for some 64cc to bump my compression up But I dont know if it would be worth it or not and the cam specs are duration 0.50 gross valve lift .470, is there anything you would do different ? iam running a TH350 lock up with a stock converter, should I go with a bigger cam?
steps350 is offline
post #5 of 10 (permalink) Old Jan 28th, 12, 05:43 AM
Michael Gekko
Re: 82 350
When you get the lower gears a larger cam would be a good idea imo.....you could just pull the heads and get them cut down..thaat and using a thin metal gasket would help bump the compression by maybe a point. I wouldn't change the heads just to get a smaller chamber, not a great enough gain in power to offset the cost.
The best thing to do imo is to start building another 350 or 383 shortblock, one that is more appropriate for you long term power desires....then put those heads on that new engine along with a better intake and 750 vs carb. You can get close to building a new shortblock for the price of new heads. Put 10-1 forged pistons in the new shortblock .
The problem with doing a piecemeal changeout in your current engine is that it will be mismatched and you won't achieve the performance gains that you are looking for while you are making the changes.
post #6 of 10 (permalink) Old Jan 28th, 12, 12:15 PM Thread Starter
corey
Re: 82 350
Ah I see your point, I think thats what I will do then is build another engine hey what kinda of pistons are a good idea ? flat tops? and is a stock 350 crank strong enough or should I change that out?
steps350 is offline
post #7 of 10 (permalink) Old Jan 28th, 12, 01:09 PM
Michael Gekko
Re: 82 350
I would recommend a good forged flat top piston and a stock steel 350 crank will certainly do the job for you. You can find the crank by searching Ebay and Craigs List, or call some local engine shops.
post #8 of 10 (permalink) Old Jan 28th, 12, 05:46 PM Thread Starter
corey
Re: 82 350
ok I will do that, hey is there a better intake I can put on my current motor that is bettr then the performer rpm? like one that will go better with the heads
steps350 is offline
post #9 of 10 (permalink) Old Jan 28th, 12, 06:14 PM
Michael Gekko
Re: 82 350
IMO the Performer RPM is a pretty good choice with the heads you have now. If I were you I would plan on using it-and once you get to a point where a single plane intake may make more power then you can switch them. Easy task, not much coin.
post #10 of 10 (permalink) Old Jan 29th, 12, 12:01 PM Thread Starter
corey
Re: 82 350
ok I will do that then, I took your advice I am picking up a 4bolt main on tuseday to start out fresh with , I will probably have more questions but thanks for steering me in the right direction
steps350 is offline
