dodge trouble - Team Camaro Tech
Non-Camaro Tech Problems and Issues with your daily driver or other non-Camaro vehicles.
post #1 of 8 (permalink) Old Feb 14th, 12, 01:41 PM Thread Starter
Big daddy
dodge trouble
My sons 2003 stratus,the heat will not heat,I changed the stat,no change heater core not leaking.Hose to heater core hot.the heater controls work in all positions.Could the heater core be blocked?Thanks hate non chevy troubles.
67ssclone 383 4spd 3.73 vintageair
carhodge is offline
post #2 of 8 (permalink) Old Feb 14th, 12, 05:12 PM
Re: dodge trouble
Check both hoses in and out of the core. Both warm, core works, return hose is cold, core plugged.
Could be the air temp door/actuator not working.
post #3 of 8 (permalink) Old Feb 14th, 12, 05:14 PM
Kevin
SixtyAte's Avatar
Re: dodge trouble
Check the inlet hose and the outlet hose on the heater core. If the inlet is hot but the outlet is cold....the core is bad and hot water is not flowing through it.
Kev
SixtyAte is offline
post #4 of 8 (permalink) Old Feb 14th, 12, 05:28 PM
Re: dodge trouble
There may also be a heater control valve on the hose going into or out of the heater core. I would think something like that would be in the engine compartment, but who knows or if that vehicle even has one but if it's stopping the water flow it could make you think the core is plugged up.
SOA-Nova is online now
post #5 of 8 (permalink) Old Feb 14th, 12, 06:34 PM
Re: dodge trouble
I just went through this with my 98 Dakota - not that it's necessarily a Dodge only problem. I backflushed the heater core and it now works great.
Felt the hoses and found one hot and one cold, so assumed that the hot was the in and the cold was the out. Disconnected both at the engine and blew all of the coolant out gently with compressed air. Used a funnel and poured half a bottle of CLR into the outlet hose and let that stew in there for an hour. Then hooked the garden hose to the outlet side of the heater core and flushed all of the crap out in the opposite direction of normal flow. Hooked it back up and the heater works great.
BPOS is offline
post #6 of 8 (permalink) Old Feb 15th, 12, 05:16 AM Thread Starter
Big daddy
Re: dodge trouble
checked hose and found one hot inlet and the other just barely warm,will try the back flush thing.Thanks all,will report back.
carhodge is offline
post #7 of 8 (permalink) Old Feb 15th, 12, 01:29 PM Thread Starter
Big daddy
Re: dodge trouble
Hey guys,thanks a bunch,did back flush on heater core and,it worked.So hot now could hardly stand it.Now I'am still a hero to my son.He thinks dad can do anything.
carhodge is offline
post #8 of 8 (permalink) Old Feb 15th, 12, 02:37 PM
Re: dodge trouble
Most important point in Son's mind. Congrats!
We parents are their 'rock.'
