I need some suggestions - Team Camaro Tech
Non-Camaro Tech Problems and Issues with your daily driver or other non-Camaro vehicles.
post #1 of 17 (permalink) Old Feb 20th, 12, 11:05 AM Thread Starter
V.J.
vjp819's Avatar
Guys I have a work truck 97 nissan pickup. Had it for a lot of years without the first problem. Now I have one, and really don't know where to start. 2.4 engine.
Every now and then, last time this happened was about 6 months ago. But when leaving a traffic light the engine sputters really bad. It doesn't kill, but if you accelerate hard, and get up some speed, it feels like you are shutting off the ignition, then turning it back on. Over and over. The sound that the engine makes is the same as it would be at a speed of 50 or so, and you would shut off the engine, then turn the key back on. I believe that the engine is actually dying, then restarting because I'm rolling in gear. I know it's either electrical or fuel, but I'm not sure what to test, and because it doesn't do it all the time, if even it would show up. Does anyone have any suggestions? I have another vehicle which I will be using until this is solved, and will be using it because I go through some not so safe areas on my way to work. Just please give me a place to start. TIA.
1968 LeMans Blue Camaro-Resto in progress
vjp819 is offline
post #2 of 17 (permalink) Old Feb 20th, 12, 11:27 AM
Kevin
SixtyAte's Avatar
Re: I need some suggestions
I would say to see if there are any codes stored. Most AutoZone and Advance Auto stores will do it for free. To me is sounds electrical in nature like intermittent spark. Some say check EGR and Fuel pressure however I would do that as the last resort. Get codes, make sure EGR is not sticking and run the engine at night in the dark looking for spark jumping.
Kev
SixtyAte is offline
post #3 of 17 (permalink) Old Feb 20th, 12, 11:56 AM Thread Starter
V.J.
vjp819's Avatar
Thanks, looking for spark is one thing i'm going to do, and also check the distributor cap. But the last time it did this none of those two things were the problem. Actually I never did find the problem it just stopped doing it for 6 months. This problem doesn't trigger the "check engine" light. Will it still show a code if the check engine light doesn't illuminate?
vjp819 is offline
post #4 of 17 (permalink) Old Feb 20th, 12, 03:34 PM
DjD
DjD's Avatar
I had an old truck with 2 fuel tanks and each had it's own fuel pump. One tank had a failing fuel pump and it sounds like you described it perfectly when I tried driving around on the one tank!
...Dennis
DjD is offline
post #5 of 17 (permalink) Old Feb 20th, 12, 03:45 PM
One common problem with Nissan trucks was/is the fuel pump relay.
Might start there, cheaper and easier to replace.
post #6 of 17 (permalink) Old Feb 20th, 12, 06:15 PM Thread Starter
V.J.
vjp819's Avatar
Thanks guys gonna look at both when i get a couple days off
vjp819 is offline
post #7 of 17 (permalink) Old Feb 21st, 12, 04:22 AM
1st 67 SS/RS's Avatar
I have an 88' kingcab SEV6 with 328k on it and had a similar problem about 9 years ago, turned out to be a short in the wiring.
67 Vert RS/SS 350 4 SP
1st 67 SS/RS is offline
post #8 of 17 (permalink) Old Feb 21st, 12, 10:29 AM Thread Starter
V.J.
vjp819's Avatar
thanks scott. ignition short is something i've got to look at. it does feel like i'm turning the key off and on again while getting down on the accelerator. that engine would make the exact same sound if I accelerated hard to reach a speed of 50 or so as if i were to turn off the key, rolled for about 60-70 feet. then suddenly switch it back on over and over, but if i were to drive at a constant speed of 40 or 50 its not noticeable. almost sounds like a couple of other posters suggested the fuel pump or relay too. if that relay is sticking that might answer why this isn't something that happens every time i drive the truck, but only periodically.
vjp819 is offline
post #9 of 17 (permalink) Old Feb 23rd, 12, 08:28 PM
JAY
There are alot of issue's with fuel pump relay...I believe its a blue relay and may be mounted on rf inner fender. We always got them from the dealer, but last time I got one aftermarket it was a Nissan one in after market box. also when was fuel filter changed last...alwaqys a GOOD starting place on those kind of problems! j
66 SS Chevyll
67 Elcamino
68 Malibu 2dr
69 Camaro Convertible
JAYARTER is offline
post #10 of 17 (permalink) Old Feb 23rd, 12, 08:55 PM Thread Starter
V.J.
vjp819's Avatar
Thanks Jay, I have a couple days off finally, and I hope to have a little time to look into all the suggestions you guys have offered. The truck does have nearly 200,000 miles on it and the fuel filter hasn't ever been changed. In fact before looking for it, I never even knew where it was located.
vjp819 is offline
post #11 of 17 (permalink) Old Feb 24th, 12, 03:15 AM
Fuel filter clamped onto the inside of the frame rail.
Easiest way to find it is buy one and look for a simular item throughout the truck.
post #12 of 17 (permalink) Old Feb 24th, 12, 07:58 AM
Vintage 68's Avatar
Wink Re: I need some suggestions
Along with hooking a Fuel-Pressure gauge to the system and monitoring it as you drive - I'd recommend doing a diagnostic check of the TPS (throttle-position-sensor) and be sure it's response is linear and to spec.
A failing pump or clogged filter with lead to fuel pressure failing to maintain spec. at acceleration.
Failure to maintain pressure under load or at top end will often be a failed/failing Pressure Regulator - you can check vacuum diaphragm with a short piece of tubing or use a hand vacuum source if you have one. You should see noticeable change in the fuel pressure readings while applying vacuum to the unit.
I've found and fixed several driveability issues same as this due to defective/failing TPS units ...
Also be sure to check the rear of the Throttle Blade (in the Throttle Body) and clean it if coated with soot - a dirty throttle blade will upset the air-flow to the sensor and delay enrichment response from off-idle transition thru at-cruise conditions.
1968 Convertible
Some trucks
Vintage 68 is offline
post #13 of 17 (permalink) Old Apr 24th, 12, 08:00 PM Thread Starter
V.J.
vjp819's Avatar
Well a couple weeks ago I had a little time to pull the tank and look at the fuel pump. When I pulled it out, the filter attached to it had some really fine particles stuck it it. I'm not sure what it was although it looked orange in color and didn't appear to be rust. The tank was otherwise clean. I know the plugging of the filter sock had a lot to do with the eventual failure of the fuel pump. I replaced the pump, pump filter and fuel filter in the engine compartment. It's run fine ever since. I'm just happy the truck never left me stuck on some road somewhere.
vjp819 is offline
post #14 of 17 (permalink) Old Apr 25th, 12, 03:37 AM
Kewl! Thanks for the update.
Good to know what fixed it.
Orange stuff, huh?
post #15 of 17 (permalink) Old Apr 25th, 12, 07:04 AM
I'd put $$$ on that dirty mass flow sensor (throttle blade). Older units after a fair bit of m/km tend to muck up the fuel system. You may have to take off to clean properly.
capt
Bumper sticker- I'm not SPEEDING
I'm QUALIFYING!
captcanuck68 is offline
