2007 Silverado Using Oil - Team Camaro Tech
Non-Camaro Tech Problems and Issues with your daily driver or other non-Camaro vehicles.
post #1 of 23 (permalink) Old Mar 13th, 12, 07:14 PM Thread Starter
I have a 2007 Silverado 4x4 with the 5.3 engine and active fuel management (shuts down 4 cylinders when not under load). Back in the fall, I had the low oil light come on with only around 3200 miles since the last oil change. I ended up adding 2.5 quarts to put it back to the full mark. Two weeks ago, the same thing happend to me again. Around 3200 miles and the low oil light came on again. I added 1.5 quarts to bring the level up into the safe range (according to the dipstick - would have held another quart to bring it up to the full level). I visited my local Chevrolet dealer where I purchased the truck and they did not seem that surprised that my truck is burning oil. It just turned 40k miles! Their first attempt at repairing the problem is to change the left valve cover because the replacement is supposed to have some sort of baffle in it to help with oil consumption. They lead me to believe that this would not fix the problem but is what GM is requiring them to do as the first attempt to fix the problem. The part is currently on backorder so I am patiently waiting.
Has anyone else experienced oil loss with one of these engines? After searching the internet, I have read quite a few stories about oil loss with primarily the 2007 models in several GM vehicles that use these engines. Also, I only have used Mobile One 5000 conventional oil in this truck since new, never ran synthetic in it. I have always changed the oil between 3000 to 3500 miles even though the oil monitor says there is still around 40% oil life left. Just curious if anyone else has had any experiences such as this. Thanks for your time.
68 Camaro SS396
MSCHMIDT9090 is offline
post #2 of 23 (permalink) Old Mar 13th, 12, 07:56 PM
DT
Donny
DT's Avatar
Re: 2007 Silverado Using Oil
Mike I have a 2007 Tahoe LTZ. No oil leaks or anything. I can relate my experience with Mobil 1 synthetic though. 4,000 miles seems to be when the oil starts to disappear ( for whatever reason). I had this experience with 3 trucks already. I told some friends about it who also used Mobil 1 synthetic and sure enough they experienced the same problem. My recommendation would be to use synthetic blend (half dino, half synthetic) I haven't had a problem since with oil disappearing.
DT is online now
post #3 of 23 (permalink) Old Mar 13th, 12, 07:59 PM
kt
kelly
seen this before, gm spec is 1 liter per 3200 kilometers any thing under that kms its a issue, if it uses more than whats allowed it gets the engine decarb'ed and a deflector in the crank case, the repair looks after that in almost all cases. if it still burns more that whats allowed then it gets rings and pistons. Dont read into the net to much….its full of bad..lol...
kt is offline
post #4 of 23 (permalink) Old Mar 13th, 12, 08:21 PM
I have the same truck and engine and also have the same issue. Mine started somewhere around 75,000 miles and I now have around 115,000 on it. I usually have to add around half a quart at the 3,000 mile mark. It doesn't seem to have gotten any worse however. I've never asked the dealer about it or anything.
Z11Scott is offline
post #5 of 23 (permalink) Old Mar 13th, 12, 08:26 PM
Derek
97 CAIVIAROSS's Avatar
Send a message via AIM to 97 CAIVIAROSS
My buddy has the same problem. Has a ledger to keep tabs on it. Has had it back to the dealer 3 times for it. First time they may have done the valve cover. Second time was the engine decarboning and third was the splash shield or windage tray. They told him it was in the ring pack design for 07 08 5.3 with cylinder deactivation. His is still using oil don't remember how much now but he has experimented with different oils. I believe he said the GM oil has been the best as far as consumption. Wil check with him tomorrow.
Derek
97 Camaro SS #1925 6spd (Cammed, now it sounds right!)
67 Camaro SS 350 #s Matching (Being Restored..umm covered in garage
11 GMC Sierra 2500hd (Driveway Queen)
09 Impala 175,000 and still going (Work Car)
97 CAIVIAROSS is offline
post #6 of 23 (permalink) Old Mar 13th, 12, 08:30 PM
Steiner
Ugh. Sorry man. Just for the heck of it I'd go up a weight (40 if you're using 30) and see what it does. Won't really help if it's because of a baffling problem at the PCV though which the valve cover deal would seem to imply. There are baffled PCV grommets on the shelf at the parts store (usually over in the Mr. Gasket and dress up parts section) and you could try one of those which would help keep oil off the PCV.
'69 Camaro
500hp/538lbft
Steiner is offline
post #7 of 23 (permalink) Old Mar 14th, 12, 02:54 AM Thread Starter
Never ran synthetic in it, always conventional oil - 5W-30 as stated in the manual.
Originally Posted by kt View Post
seen this before, gm spec is 1 liter per 3200 kilometers any thing under that kms its a issue, if it uses more than whats allowed it gets the engine decarb'ed and a deflector in the crank case, the repair looks after that in almost all cases. if it still burns more that whats allowed then it gets rings and pistons. Dont read into the net to muchÖ.its full of bad..lol...
Roughly 1 quart per 2k miles? Seems a little excessive to me considering my older trucks with the 5.3 never used a drop of oil with many more miles on the engine. Anyhow, I seem to be outside that tolerance with it using 2.5 quarts in only 3200 miles. Fortunately, I still have about nine months of warranty remaining.
Thanks for the replies!
68 Camaro SS396
post #8 of 23 (permalink) Old Mar 14th, 12, 06:42 AM
DT
Donny
DT's Avatar
Mike the blend (half & half) comes in 5W30. Valvoline Durablend.
DT is online now
post #9 of 23 (permalink) Old Mar 14th, 12, 07:00 AM
click's Avatar
I wonder why those engines are that much different than the older 350's ? My 97 tahoe doesnt burn a drop of oil at 158,000 miles and its had Amsoil 100% syn 5w-30 in it since 67,000 miles... maybe after 10 years of new technology they changed ring seating or cylinder wall machining or something ? sure seems odd.
click is offline
post #10 of 23 (permalink) Old Mar 14th, 12, 07:39 AM
Bryon
bcm66's Avatar
This is odd. Never heard of it. But sorry to hear of your problems.
My 1993 Silverado with the 5.7 started burning about half a quart by oil change time at 4000 miles, but this was only after it had over 120,000 total miles on it.
My 2002 Silverado with 5.3 never burned a drop of oil - even at 150,000 miles.
I had a 2010 Silverado with the 5.3 and active fuel management on it. That did not need any special oil, but I used Valvoline synthetic. Only had 2 oil changes on that truck, then damaged bad by hail and traded off, but to my knowledge it never used oil.
The 2011 Silverado crew cab with the 5.3 I have now with active fuel management does not seem to use any oil, but these (at least the 2011s) are now required to use GM Dexos or full synthetic.
I would maybe try a different oil. I have had good luck with Valvoline full synthetic.
68 Camaro SS 396 - 468 BBC now, M21, 12 bolt 3.73 coded housing but w/ 3.31 gears.
Looking for 68 Camaro with body number NOR 181016
CRG -
bcm66 is offline
post #11 of 23 (permalink) Old Mar 15th, 12, 04:39 PM
Virgil
I had an 05 CC SB that was doing the same thing. Ordered a new vehicle and while waiting, a friend told me to pull the "pcv" line (I know it has no real valve like we are used to) off the drivers side valve cover and clean line, down in VC etc with a good cleaner. I did this, and it seemed to have stopped the problem, as I had to drive it a while longer while waiting on the Suburban.
Seems GM knows about it,(since they changing left VC) as I do not remember a baffle in the driver's valve cover on mine. From what I understand, from his explanation, the line would get partially blocked and suck the oil thru, for some reason.
Just something to check into.
vr1967 is offline
post #12 of 23 (permalink) Old Mar 15th, 12, 05:55 PM
Derek
Talked to my buddy. He said as per GM 1 quart for every 1000 miles is acceptable. He has tried all different kinds of oil. Does not matter so he sticks with conventional to keep the cost down. If it consumes more then that they would but new pistons with the updated ring pack in it.
Personally I think that 1quart for every 1000 is absolutely ridiculous.
post #13 of 23 (permalink) Old Mar 15th, 12, 05:59 PM
Derek
This problem affected 07-08 5.3 with the cylinder deactivation. Updated ring pack was used in 09 and up.
post #14 of 23 (permalink) Old Mar 15th, 12, 08:00 PM
Matt
I have had the same problem with my 07 GMC. I took it to the dealer repeatedly for them to "monitor" the situation. I also got the "itís acceptable" answer. I suspect that they will tell everyone that because if they admit to having a problem with those specific engines then they will have to fix virtually all of them and that is just not cost effective.
GM loses credibility every day. Itís getting awful difficult to remain brand loyal to them when there are so many reasons not to be. It seems like the company line these days is telling customers that a problem is not really a problem just so they donít have to address the actual problem. With todayís technology it is absolutely unacceptable for an engine to burn oil like that especially when there are no visible signs of leakage. I have two other cars that clearly leak oil and still donít have to have oil added between oil changes.
vmatt350 is offline
post #15 of 23 (permalink) Old Mar 15th, 12, 09:09 PM
Steiner
GM isn't the only one who says 1 quart per 1000 miles. Practically every manufacturer gives a number anywhere from 1 liter per 1000km to 1 quart per 1000 miles as acceptable.
'69 Camaro
500hp/538lbft
Steiner is offline
