Rear radio antenna routing diagram - Team Camaro Tech
Non-Camaro Tech Problems and Issues with your daily driver or other non-Camaro vehicles.
post #1 of 3 (permalink) Old May 24th, 12, 03:16 AM Thread Starter
dude67=John
Hello,
I am from the Team Chevelle website and it seems that there is no diagram for this in the the Chevelle factory assy manual. I'm trying to install the rear antenna back in my 67 Chevelle. I can't remember how it was routed. My Factory Assy. Manual only show where is comes thru the 1/4 panel. Does anyone have another diagram with the routing of this cable and the sheet metal cover and clamps? I was thinking that the camaro might have this. Thanks.
dude67 is offline
post #2 of 3 (permalink) Old May 24th, 12, 03:57 AM
Re: Rear radio antenna routing diagram
Welcome, John. Fisher Body Manual would be the one to use as AIM just shows, as you say, the antenna attached to the qtr panel and description says antenna lead to Fisher Body.
Well, I looked in FBM, and I did not find anything, even no radio, antenna, nor anything concerning an antenna lead, unless I looked in the wrong place, Index where I looked.
However, having owned an U73 optioned '68 Camaro, the lead ran forward on the right side of the tub seam then ran in the rocker panel under the door sill plate, then came up pass side just on the other side of metal structure, then across to radio under the glovebox.
Hope this helps, maybe another member can give better instructions and point out the exact place to look.
post #3 of 3 (permalink) Old May 24th, 12, 07:29 AM Thread Starter
dude67=John
Well Thanks Jake. I didn't see that note. It says it in my FAM too. "Installed by Fisher Body" I looked in my 67 Body by Fisher service manual. I didn't find anything in there ether. You would think that it would be standard through out the whole A-Z lines.
dude67 is offline
