New brakes - New issues (my truck not Camaro) - Team Camaro Tech
Non-Camaro Tech Problems and Issues with your daily driver or other non-Camaro vehicles.
post #1 of 4 (permalink) Old May 30th, 12, 08:33 AM Thread Starter
Matt
Posting in bench racing as this is about my truck rather than camaro. Hoping to get some advice from the gurus here. I changed front brake pads on my 08 Dodge Ram 1500 over the weekend. Had the rotors turned as well. Put all back together and now get a wobble/pulsating feeling when applying the brake. I feel it through the brake pedal. This is very visible at higher speeds. I double checked the torque (130 ft/lbs) on the lug nuts as the manual says that's very important to avoid rotor warping. Hoping that something is not seated right but I have a feeling my rotors are warped.
Thanks in advance for any feedback.
Matt
zlek131 is offline
post #2 of 4 (permalink) Old May 30th, 12, 08:59 AM
Vintage 68's Avatar
Unhappy Re: New brakes - New issues (my truck not camaro)
Originally Posted by zlek131 View Post
... Hoping that something is not seated right but I have a feeling my rotors are warped.
They 'goofed-up' the set-up of the unit and turned a warp into your rotor(s) for you
My advise is to check the 'Run-out' of each of the rotors and return the one(s) they miss-turned to them for correction ...
I my experience, the person doing the 'turning' is more of a problem than any rotor I've run into
If the machining issue is great enough to be very noticeable at low speeds, then the rotor(s) are likely to be beyond their useful thickness spec.s if turned to correct.
Soooo - you may be looking at new rotors in that case.
And IF you buy new rotors - DO NOT let them try to "turn/true" them for you before you get out of there
If a 'new' rotor doesn't meet run-out spec. then return it for one that does
And from now on ...
Don't bother turning any in-service rotor that does not have a issue or only shows light surface marking - the new pads will smooth out the rotor service in no time and the pad life will be much better in the long run.
I never turn rotors that are performing correctly - and most of time will just replace a defective rotor.
This from a guy with over 400K on a set of 12" rotors on his old truck
1968 Convertible
Some trucks
Vintage 68 is offline
post #3 of 4 (permalink) Old May 30th, 12, 11:16 AM Thread Starter
Matt
Yeah I had a feeling that's what they did (turned warp into the rotors). Deep inside I knew I shouldn't have turned them and simply installed new pads and be done with it. Sounds like I caused myself additional work. I'll check the run-out and rotor thickness in the next few days and go from there. Thanks for your feedback.
Matt
zlek131 is offline
post #4 of 4 (permalink) Old May 30th, 12, 05:38 PM
Steiner
Re: New brakes - New issues (my truck not Camaro)
I didn't know Dodge was making rotors thick enough to even be turned now. I've read that the Challengers have a real big problem with the rotors being undersized and warping very early. Changed all pads on the Durango at 60k service to be safe. All was well.
'69 Camaro
500hp/538lbft
Steiner is offline
