can someone help decode these engine numbers? - Team Camaro Tech
Non-Camaro Tech Problems and Issues with your daily driver or other non-Camaro vehicles.
post #1 of 4 (permalink) Old May 30th, 12, 04:05 PM Thread Starter
These are the numbers that are on the chevy 350 engine that is in my 69 chevy truck. My neighbor showed me a site he found that said the motor was a 73 camaro 350. Now I'm trying to track these numbers myself.
13B419492 T0918CKL
thanks,
Betty
Name:	1st setnumbers.jpg
ID:	28756   Click image for larger version
flchevygrl is offline
post #2 of 4 (permalink) Old May 30th, 12, 04:46 PM
DjD
DjD's Avatar
Re: can someone help decode these engine numbers?
Check this thread out...
https://www.camaros.net/forums/showthread.php?p=687268
...Dennis
DjD is offline
post #3 of 4 (permalink) Old May 30th, 12, 08:38 PM Thread Starter
one site I found said it was a z28 engine.. is that true?
How would I find specs for it when I want to rebuild the motor?
thanks,
Betty
post #4 of 4 (permalink) Old May 31st, 12, 01:44 PM
Vintage 68's Avatar
Wink Re: can someone help decode these engine numbers?
Originally Posted by flchevygrl View Post
one site I found said it was a z28 engine ...
thanks,
Betty
Most likely the same folks wrote that site as painted this sign - Click image for larger version
Name:	Stop Sign ... not.jpg
It is a RPO-L65 350c.i. small block assembled in Sept of 1972 for a 1973 model Chevelle/ElCamino.
Decode is;
(13B419492)
1 = Chevrolet Division of GM
3 = 1973 'Model' year
B = Baltimore, MA Final Assembly plant
419492 = the sequential VIN numbering
(T0918CKL)
T = Tonawanda, NY Engine plant
09 = Sept. month of assembly
18 = 18th day of the month assembly
CKL = Usage Suffix - RPO-L65 350c.i. with TH400 trans, 145HP, Single 2bbl carb.
The CKL Suffix designator was used in two (2) vehicles for the 1973 model year - the Chevelle/ElCamino and the Impala.
The Baltimore plant only assembled A and A-Special bodied GM vehicles - so it could only be a Chevelle in this case, not an Impala (which were assembled in Arlington, TX and Oshawa, ONT. Canada) ...
1968 Convertible
Some trucks
Vintage 68 is offline
