Ressurecting mothballed rebuilt motor - Team Camaro Tech
Non-Camaro Tech Problems and Issues with your daily driver or other non-Camaro vehicles.
post #1 of 14 (permalink) Old Jun 4th, 12, 07:18 AM Thread Starter
Bill
Calpantera's Avatar
OK so not really mothballed, it sat under the hood for 20 years but never fired. The motor is a 351 Windsor in my sons 69 Ranchero he got from his grandfather. Grandad rebuilt it and put it in but never fired it up. He did put oil in it and when I pull the dip stick I see nice clean oil and no signs of water or anything else. It had plugs, exhaust manifolds and an air cleaner on it the whole time but the car did sit outside but in a really dry part of California (Paso Robles). There was no radiator hoses installed though. So how far do I go back into this thing before firing it up? I am assuming I will go ahead and yank it back out so I can clean up the engine bay anyway. I will pull the pan and take a look to make sure there is not signs of rust in there but should I pull the cam and relube it or just pull the manifold and lifters, prelube them and put some lube on the cam lobes while it is still in there? I am also kinda worried about the crank seals, should I try to lube them somehow before turning the motor. I have not turned it at all in fear of a seal being stuck to the crank and tearing. Also has a rebuilt C5 trans but it never had any fuild and the lines were not hooked up. I am going to go ahead and pull the pan on that too and see how it looks. Suggestions?
Thanks!
Calpantera is offline
post #2 of 14 (permalink) Old Jun 4th, 12, 07:49 AM
Jeff
yellow69RS's Avatar
Re: Ressurecting mothballed rebuilt motor
I've got a 305 in similar condition, but it has miles on it. I rebuilt it and drove it maybe 10,00 miles and it been sitting ever since. I didn't think it would sit over 10 years so no oil in cylinders or any other precautions. I'll be pulling the heads to see how much rust in the cylinders then I'll go from there, possible re-ring and check the bearings. Alot depends on budget at the time I'm ready to open it up.
Jeff
yellow69RS is offline
post #3 of 14 (permalink) Old Jun 4th, 12, 08:41 AM
I would take the spark plugs out and view with a borescope the cyl walls.
I would even turn the engine over by hand and spray the bejesus of every cylinder with WD40.
I would install a fresh battery and remote start button and crank it, then reinstall the spark plugs.
I would hook up a fresh gas can to the fuel pump, maybe pull a bowl off the carb to see the cleanliness of the bowl. You know the rest of the fuel delivery system will need tending.
I would change engine oil & filter.
I would then fire this puppy up!
Oh, fill trans and keep an eye on it also since its built.
I would then say sub-consciously "Thank you, Granddad."
Harbor Freight has a borescope for $80, if you need a coupon, PM me and I'll send you one from my weekly mail from them.
post #4 of 14 (permalink) Old Jun 4th, 12, 10:19 AM
foreverlookin's Avatar
I would prime the motor after changing the oil by pulling the distributor running the pump with this:
http://www.autozone.com/autozone/acc...ier=85900_0_0_
foreverlookin is offline
post #5 of 14 (permalink) Old Jun 4th, 12, 12:45 PM
Definitely prime it first, then roll it by hand after/between primings and squirting the walls with WD40.
69 Pace Car and 69 Hard top
srode is offline
post #6 of 14 (permalink) Old Jun 4th, 12, 01:26 PM Thread Starter
Bill
Calpantera's Avatar
Everette that was my first thought then I started thinking that since it has never been fired up since the rebuild and the cam is not broken in. You think the assembly lube is still there? I think I am just going to toss on a newer Edelbrock 600 carb that used to be on the Camaro as far as carb goes.
post #7 of 14 (permalink) Old Jun 4th, 12, 01:31 PM Thread Starter
Bill
Calpantera's Avatar
Ya I would for sure use a primer tool, Autozone loans those out, I accidentally purchased the one for Chevy engines when I forgot to return the loaner
post #8 of 14 (permalink) Old Jun 4th, 12, 04:30 PM
New carb would be a good idea and a bottle of GM EOS.
post #9 of 14 (permalink) Old Jun 5th, 12, 06:29 AM Thread Starter
Bill
Calpantera's Avatar
Ya good call on the EOS. I am so tempted to just change out the oil, add some EOS, prime it and fire it up. I do need to get a rad installed and runs some trans lines, he halfway ran some custom trans lines to an external filter, I think I am going to just bypass it and go with stock lines. You think the seals on the motor and trans should be OK? At least the engine seals have had some oil against them but the trans has been sitting dry. Maybe I will blow out the trans lines with air and do the same for the water passages in the block in case any critters got in there. I have no idea if he primed the converter though.
post #10 of 14 (permalink) Old Jun 5th, 12, 08:43 AM
Reads like a good plan. Go for it!
post #11 of 14 (permalink) Old Jun 5th, 12, 01:56 PM
Jeff
yellow69RS's Avatar
If tranny was built by a shop the internal seals are probably coated with Vaseline. When I install them I coat the hub of the converter and the driveshaft yoke with gease for prelube. I've done less prep in the past then suggested above but I'm wishing you a better outcome then I've had. Good luck!
Jeff
post #12 of 14 (permalink) Old Jun 5th, 12, 03:20 PM
dave
Prelube and EOS are a great idea. But all that assembly lube on the cam and crank journals will be gone by now. Ideally the motor should be taken apart,cleaned and reassembled but it will probably be fine.Just make sure you do a REAL good job on the prelube.Good Luck!
daves69 is offline
post #13 of 14 (permalink) Old Jun 11th, 12, 01:05 PM Thread Starter
Bill
Calpantera's Avatar
Here is a vid of one of the bores I did with a scope. Looks great! I looked at 4 bores and they all looked the same. Also I now know its a nice and low comp motor for my teenage son
post #14 of 14 (permalink) Old Jun 11th, 12, 06:30 PM
I agree, looks good from here.
Squirt copius quantities of oil into them, crank it over several times, then go for it.
Looks like some assembly required.....HA!
I actually like the rear view mirror.
