Another Hood Question . . .not a Camaro - Team Camaro Tech
Non-Camaro Tech Problems and Issues with your daily driver or other non-Camaro vehicles.
post #1 of 3 (permalink) Old Jun 27th, 12, 05:23 AM Thread Starter
Bruce
My 69 C-10 Chevy Pick-up that tows my Camaro to shows has a hood issue. When I unlatch it, it does not pop up so I use a plastic tool to pry it enough to get my fingers under to open! It does not have a spring like the cars. I have adjusted the hood part of the latch in and out to no avail. Any ideas to solve this annoying issue that I have lived with for too many years!!
The Camaro Guy is offline
post #2 of 3 (permalink) Old Jun 27th, 12, 01:28 PM
Vintage 68's Avatar
Re: Another Hood Question . . .not a Camaro
The hinge springs pull the hood up a few inches when the primary latch is released on these.
If the hood hinge springs are weak they will not 'pop' it up - but, a tweaked or resistant hinge will also keep the hood from 'popping' ...
Be sure to completely clean and lube the hinge system well before replacing the springs (replace in sets).
I've see guys install a later pin with a spring on it - not sure if they were retrofitting a newer system or trying to cure the 'pop' issue
1968 Convertible
Some trucks
Vintage 68 is offline
post #3 of 3 (permalink) Old Jun 28th, 12, 05:57 AM Thread Starter
Bruce
Thanks for the info, John
