4x4 ? - Team Camaro Tech
Non-Camaro Tech Problems and Issues with your daily driver or other non-Camaro vehicles.
post #1 of 4 (permalink) Old Jul 20th, 12, 10:59 AM Thread Starter
kevin
4x4 ?
i know this dont pretain to a camaro, but i know some of you guys work on other vehicles, and i need help
i have a 05 gmc envoy. it has a select knob for 2wd, all wd, 4 wd and 4 low.
when i shift the knob from 2 to all or 4 hi. it will not engage. if i put the transmission in neutral and shift to low it will engage
i may mention the first 3 are shift on the move
would this be the switch in the dash or the actuator switch on the front differential?
flat tire is online now
post #2 of 4 (permalink) Old Jul 20th, 12, 12:17 PM
Smile Re: 4x4 ?
Does that say Auto where you say it says all wheel drive ? I ask because on the older 2002 or so pickups had a part on the transfer case that was fairly common to fail and gives the symptoms you describe. Sorry, so vague on what the part is !
TJS69 is offline
post #3 of 4 (permalink) Old Jul 20th, 12, 12:30 PM Thread Starter
kevin
Re: 4x4 ?
post #4 of 4 (permalink) Old Jul 20th, 12, 06:06 PM
Smile Re: 4x4 ?
I believe that A4WD stands for automatic four wheel drive.
I found some information for you :
During normal driving situations the transfer case can operate in the Auto 4WD mode. In the Auto 4WD mode the transfer case shift control module monitors rear wheel slip speed, based on the inputs from both the front and rear propshaft speed sensors. When the vehicle experiences a rear wheel slip condition, the transfer case shift control module sends a pulse width modulated (PWM) signal to an electronic motor, which is the transfer case encoder motor. This motor rotates the transfer case sector shaft, applying a clutch pack. This clutch pack is designed to deliver a variable amount of torque, normally delivered to the rear wheels, and transfers it to the front wheels. Torque is then ramped up to the front wheels until the front propshaft speed sensor matches that of the rear propshaft speed sensor. Torque is then ramped down until torque is completely removed from the front wheels or until rear wheel slip is once again detected. The process would then repeat.
TJS69 is offline
