1969 Chevelle SS? Trim Tag info? - Team Camaro Tech
Non-Camaro Tech Problems and Issues with your daily driver or other non-Camaro vehicles.
post #1 of 3 (permalink) Old Jul 24th, 12, 02:26 PM Thread Starter
ENP
My buddy bought a 69 SS Chevelle. He was told its a SS. It doesn't have the orignal motor nor tranny. Here is the trim tag. Does any Chevelle experts on here have an opinion.
ENP is offline
post #2 of 3 (permalink) Old Jul 24th, 12, 02:36 PM
Bryon
bcm66's Avatar
Re: 1969 Chevelle SS? Trim Tag info?
Best place to check is here at this link.
http://www.chevellestuff.net/1969/69ss.htm
For 69 Chevelles, two exterior paint colors coded "72" for Monaco/Hugger Orange and "76" for Daytona Yellow were paint choices ONLY when the SS396 option was ordered.
The only way to truly document a 1969 Chevelle as having the SS396 option, aside from the two paint codes mentioned above, is with some sort of paperwork showing the option itself or the engine suffix code and the car's VIN. Examples would be the build sheet, Chassis Broadcast Copy sheet, warranty card protect-o-plate, or an original factory stamped engine where the partial VIN stamping is a match to the car's VIN.
68 Camaro SS 396 - 468 BBC now, M21, 12 bolt 3.73 coded housing but w/ 3.31 gears.
Looking for 68 Camaro with body number NOR 181016
CRG -
bcm66 is offline
post #3 of 3 (permalink) Old Jul 25th, 12, 12:55 PM
Bryon
bcm66's Avatar
Bottom line, unless you can find the original engine, you will never be able to prove that car is an SS.
CRG -
bcm66 is offline
