What Year Camaro rear disk brakes do I have? - Team Camaro Tech
Non-Camaro Tech Problems and Issues with your daily driver or other non-Camaro vehicles.
post #1 of 21 (permalink) Old Aug 22nd, 12, 10:21 PM Thread Starter
Thomas
We need some help here. My cousin purchased a 55 Chevy which came with a Camaro rear disk brake system. How can we identify what year the disk brakes are from? One thing we noticed right off, is the caliper on the driver side is forward of the rotor, and is at the rear of the rotor on the passenger side. Not sure why that is. Knowing what Gen the disk brake system is from would be a big help. Thanks for your support, Tommy.
CamaroV-6 is offline
post #2 of 21 (permalink) Old Aug 22nd, 12, 10:46 PM
David Pozzi
davidpozzi's Avatar
Re: What Year Camaro rear disk brakes do I have?
Cast iron?
Brake rotor diameter and thickness, is it vented or solid?
How about a better description?
davidpozzi is offline
post #3 of 21 (permalink) Old Aug 22nd, 12, 10:54 PM Thread Starter
Thomas
Exactly what info do you need and I'll ask him tomorrow? Thank you, Tommy.
post #4 of 21 (permalink) Old Aug 23rd, 12, 04:17 AM
Guess
HwyStarJoe's Avatar
As David asked, are the calipers iron or aluminum? Are they vented with fins, or the typical solid chunk?
There may be numbers cast into them. What are they?
Having one forward and one rearward is typical.
HwyStarJoe is offline
post #5 of 21 (permalink) Old Aug 23rd, 12, 06:32 AM
Michael
Picture would be better.
mahunt is offline
post #6 of 21 (permalink) Old Aug 23rd, 12, 08:29 AM
DjD
DjD's Avatar
Most likely not JL8 rear disc's, and I don't think any 2nd gens came factory with rear disc's so that would rule out 1967 through 1981. In 1982 the 3rd gen was available with rpo J65 front and rear power disc brakes so that's your starting point.
Help us out with some design characteristics, what type of parking brake? How is it operated? Are there backing plates? How are the brakes attached to the axle housing? Was the axle housing retrofitted along with the brakes?
...Dennis
DjD is offline
post #7 of 21 (permalink) Old Aug 23rd, 12, 11:48 AM Thread Starter
Thomas
Looks like I need to go to his house to take some pictures and take some measurements. I will get back to you with some answers. Thank you very much for your support, Tommy.
post #8 of 21 (permalink) Old Aug 23rd, 12, 09:50 PM Thread Starter
Thomas
I took these pictures. Hope they help. The rotor has an 11" diameter. The center hole is 2-3/4". It is 7/8" thick and made of cast iron. The 2nd and 3rd pictures are numbers on the inside of the rotor. The 4th picture is of the backing plate. The 5th picture is of the rear end housing which is a Camaro rear end. The 6th picture is of the emergency brake cable and brackets. The 7th picture is an end view of the caliper. Thanks for your support, Tommy.
post #9 of 21 (permalink) Old Aug 24th, 12, 08:10 AM
DjD
DjD's Avatar
Tommy those pictures are so small, it's really hard to say too much. I can see the spring perch in the last shot is not from a Camaro at all, looks like aftermarket or Mopar. They are often used when an axle housing was originally a coil spring unit but I can't see enough to really say more on the housing, the squared off dog ears at the bottom suggest an 8.5" rear. The shot with the e-brake cable doesn't look like a 3rd or 4th gen Camaro caliper to me, let's see what others say...
...Dennis
DjD is offline
post #10 of 21 (permalink) Old Aug 24th, 12, 08:49 AM
I can't tell you what they are but I can tell you what they aren't. They are not 93-97 LT1 Camaro nor are they 98-02 LS1 Camaro. If they're even Camaro calipers, they are 92 or earlier. They could be late 80's Firebird or Cad Seville but that's just a guess.
BPOS is offline
post #11 of 21 (permalink) Old Aug 24th, 12, 10:30 AM Thread Starter
Thomas
I just found these pictures on the internet. For the 1st picture, the person who posted it says it is from a 94-95 Trans Am. That entire rear end appears to be the same one that I have. For the second picture, the person who posted it, says it is for a 79-81 Camaro/Trans Am. Do any of these pictures look familiar to anyone? Thank you for your support, Tommy.
post #12 of 21 (permalink) Old Aug 24th, 12, 11:59 AM Thread Starter
Thomas
Ok, problem solved. I found these 3 pictures on the internet. This rear end housing is from a 1970 to 1981 Trans Am/Camaro. It is indentical to the one that we have. Thank you for your support, Tommy.
post #13 of 21 (permalink) Old Aug 24th, 12, 12:10 PM
Guess
HwyStarJoe's Avatar
I agree with Dennis... your spring perches are not the 'pocket' type. Yours are different, they're small and flat.
post #14 of 21 (permalink) Old Aug 24th, 12, 01:10 PM
Being that the rear is under a 55 Chev the originals were probably cut off and new/different perches welded on.
BPOS is offline
post #15 of 21 (permalink) Old Aug 24th, 12, 02:03 PM
Vintage 68's Avatar
Wink Re: What Year Camaro rear disk brakes do I have?
Sorry I'm so late to the parade on this
Those are 1979~early 80's GM RPO-J65 rear disc system.
They were used on several vehicles in the Pont. Cad. and Buick lines.
Only the vehicles with a 4 3/4" pattern are usable for rotors, but most of the rest of the parts are interchangable.
Cousin still has a 1979 Firebird Formula with that system ...
There is a great thread on 'NastyZ' with info - http://www.nastyz28.com/forum/showthread.php?t=88613
1968 Convertible
Some trucks
Vintage 68 is offline
