Can someone help me to identify this rear end? - Team Camaro Tech
Non-Camaro Tech Problems and Issues with your daily driver or other non-Camaro vehicles.
post #1 of 9 (permalink) Old Sep 13th, 12, 03:06 PM Thread Starter
Super 8
It came in my 1968 Firebird, and straight away I knew it was the wrong rear end. It was too wide, and was replaced recently. Now I am trying to sell it and want to know its intended application. So far I know it's a GM 10 bolt 8.5"
The codes found on the diff:
-GM30
-D209
-1254333
(could not locate any codes on the axle tubes)
From hub-to-hub it is 54.5" and wheel mounting surface-to-wheel mounting surface it is 61"
Pictures:
tumbler510 is offline
post #2 of 9 (permalink) Old Sep 13th, 12, 03:37 PM
Re: Can someone help me to identify this rear end?
Didn't see the code, but here you go....http://www.novaresource.org/axle.htm
And looks to be an 8.5"
68 Camaro~LSx ~all motor
post #3 of 9 (permalink) Old Sep 13th, 12, 04:24 PM
DjD
DjD's Avatar
With the dimensions he posted it's not Nova Doug...
...Dennis
DjD is offline
post #4 of 9 (permalink) Old Sep 13th, 12, 09:17 PM Thread Starter
Super 8
Yeah, the dimensions are too wide for a Nova. The replacement axle that I put into my '68 Firebird was from a similar yeared Nova, and it fits like a glove.
Just measured center spring perch to center spring perch. 45"
post #5 of 9 (permalink) Old Sep 13th, 12, 10:59 PM
Vintage 68's Avatar
Wink Re: Can someone help me to identify this rear end?
Looks like a 1979 Firebird rear axle.
The assembly and application code should be here - Click image for larger version
Name:	1979 Firebird rear axle.jpg
They can be a real bear to find on some units - very lightly stamped and rusting doesn't help ...
1968 Convertible
Some trucks
Vintage 68 is offline
post #6 of 9 (permalink) Old Sep 14th, 12, 08:28 AM Thread Starter
Super 8
The assembly and application code should be here - Attachment 30050
Thanks. I power washed it yesterday, but didnt see any more numbers besides the ones on the diff itself. Ill go out with a wire brush today and go to town. I found a chart here (http://www.oldsmobility.com/old/10bolt-tech.htm) that says the applications of this axle are: 70-76 Chevrolet
70-76 Chevelle
70-75 Chevy II
70-81 Camaro
70-81 GTO/Firebird
70-76 Olds F-85
72-81 Z-28
Which works with your theory.m
Are the numbers indented into the metal, or raised?
post #7 of 9 (permalink) Old Sep 18th, 12, 08:04 AM
Vintage 68's Avatar
Thumbs up Re: Can someone help me to identify this rear end?
They are 'stamped' in axle tube.
For some reason the guy doing almost all the 1970's rear axles did a very poor job of wacking the gang stamp holder with a hammer
Most are very hard to read and years of weather and rust sure don't help ...
Here's a 1977 axle stamp to compare - Click image for larger version
Name:	Rear Axle TAC code 1977 X-body date code.jpg
While you can read the ratio and application code, the date is almost unreadable
1968 Convertible
Some trucks
post #8 of 9 (permalink) Old Dec 18th, 12, 08:18 PM
PA Camaro Guy's Avatar
Originally Posted by tumbler510 View Post
70-76 Chevelle
70-75 Chevy II
70-81 Camaro
70-81 GTO/Firebird
70-76 Olds F-85
72-81 Z-28
I'd trend toward the upper end of the date range as suggested if that cover is original. I think GM started out with the crinkle cover (lateral fold cast into it) thinking it assisted with oiling the gears and when it was found that there was no meaningful benefit, they changed the cover design. Can confirm that the 1970 diffs had covers with the crinkle. I happen to have a '70 12 bolt camaro rear under my '69. (don't ask)
1969 Camaro 383
2.02/1.63 & 234/244 Vortec
TH350 / 12 bolt 3.73
PA Camaro Guy is offline
post #9 of 9 (permalink) Old Dec 19th, 12, 11:46 PM
looks like an 8.5 out of a 77ish-81 Trans Am or Z/28.. at least if the disc brake brackets are stock..
if it's got 3.42 gears it's worth a little more than if it's got something like 2.56 gears. count the teeth on the ring gear and divide that by the number of teeth on the pinion gear to see what the ratio is.
you don't plan sincerity.
novaderrik is offline
