C6 Corvette temperature guage not working - Team Camaro Tech
Non-Camaro Tech Problems and Issues with your daily driver or other non-Camaro vehicles.
post #1 of 6 (permalink) Old Oct 31st, 12, 07:29 AM Thread Starter
Donatocantu can
i own a 2008 chevy corvette i recently changed the thermostat to a 160 degree thermostat i was driving it yesterday and hit a dip the temperature guage stopped working and the car began to display on the dash "engine hot turn off A/C" but car was fine not hot at all and working fine drove it for a bit stopped removed battery and everything went back to normal!! today it is doing it again but nothing is wrong with car except for temp gauge not working and that message on dash
Doncan is offline
post #2 of 6 (permalink) Old Oct 31st, 12, 07:30 AM Thread Starter
Donatocantu can
Re: c6 corvette temperature guage not working
any ideas what it could be??
Doncan is offline
post #3 of 6 (permalink) Old Oct 31st, 12, 09:42 AM
Vintage 68's Avatar
Wink Re: C6 Corvette temperature guage not working
The Gauge in the IPC gets it's information/signal from the PCM.
The PCM gets it's info from the CTS (Coolant Temp. Sensor) located in the Left(Drivers) side Head.
The PCM sends it's serial buss data through the DLC (data link connector) system between the two 'boxes' via terminal #58 from the PCM to terminal #A11 on the IPC (instrument panel cluster) input.
Soooo - you either have a bad connection at the CTS, in the wiring to the PCM or in the wiring to the IPC ...
I'd really recommend you get the correct SERVICE manual from GM for your vehicle if you intend to start fixing these type of system issues.
The days of just changing out a sensor or finding an easy wiring/connector issue are gone - you need to understand the actual metrology/methodology paths on newer vehicles to fix what were once 'simple' problems
You need the exact schematics and information for YOUR vehicle to stand a chance at tracing this stuff down.
Hope this helps.
1968 Convertible
Some trucks
Vintage 68 is offline
post #4 of 6 (permalink) Old Oct 31st, 12, 12:20 PM Thread Starter
Donatocantu can
I have been researching this all day and what i have heard from several places is that my cars computer has a sensor that monitores the coolant temp and level and if it is not heating up fast enough or too fast it will send out all these codes now my ac is not cooling which i read is also done by these codes yest when i disconnected the battery everything went back to normal till today so guess i have to go back to my old thermostat
Doncan is offline
post #5 of 6 (permalink) Old Oct 31st, 12, 01:07 PM
Vintage 68's Avatar
Originally Posted by Doncan View Post
... i have heard from several places is that my cars computer has a sensor that monitores the coolant temp ...
... if it is not heating up fast enough or too fast it will send out all these codes now my ac is not cooling which i read is also done by these codes ...
... guess i have to go back to my old thermostat
It's all 'Codes' now son (with apologies to Chevy Chase)
I really doubt the thermo is actually causing the issue.
Heating 'slow'
The cold-soak to OT slope will still be the same, as far as the CTS is concerned, with a 'colder' thermo - and the edge clock of the PCM is not that 'tight'. It would need to have a decently forgiving range to assure proper response in very cold weather.
Just the full flow operation timing will be effected.
It is very easy to disturb wiring and connectors when moving it out of the way - like when changing a common part ...
Disconnecting the Battery (or better yet, just pulling the PCM fuse(s) ) is just re-setting an 'iffy' data memory - not fixing anything.
The next cycle(s) will see the issue an set that issue response again i and again - and ... until you locate issue and address it.
My money is still on an issue with wiring/connector(s) between the CTS and the PCM
No/low reference signal to the PCM from the CTS would cause the problem you're seeing ...
But what do I know ...
1968 Convertible
Some trucks
post #6 of 6 (permalink) Old Nov 1st, 12, 03:51 AM
Excellent info! More like a 'fail-protection' system - turn off those ancillary systems to keep the power plant running.
Remember, quiz on Friday...
