1967 C-10 4wd help needed - Team Camaro Tech
Non-Camaro Tech Problems and Issues with your daily driver or other non-Camaro vehicles.
post #1 of 3 (permalink) Old Nov 3rd, 12, 02:19 PM Thread Starter
Keith
OK folks, a friend of mine is rebuilding a '67 C10...
He put a 3 inch body lift kit in it, and a new power steering box.
Because of the lift, he cut the steering shaft, and attempted to install a U-joint to join the two pieces. The problem is that, when connected, the connection is flexed to a point where the locator holes do not ride the pins in the rag joint properly, popping on and off the pins as the steering wheel is turned...
Any thoughts? Is there a different rag joint with longer pins?
Thanks in advance...
Keith
1967 Camaro
Muncie M-20
GM 8.5, 3.73 posi
keithl1967 is offline
post #2 of 3 (permalink) Old Nov 3rd, 12, 03:19 PM
wayne
Re: 1967 C-10 4wd help needed
Would you be able to remove the rag joint and replace it with u-joints?http://www.flamingriver.com/index.ph...ts/c0005/s0002
2x1968muscle is offline
post #3 of 3 (permalink) Old Nov 4th, 12, 12:02 PM Thread Starter
Keith
He's already got a similar ujoint in the middle of the shaft...it is just not quite long enough to keep the rag joint form flexing off of the pins...
Keith
1967 Camaro
Muncie M-20
GM 8.5, 3.73 posi
