2002 chevy avalanche fuel pump - Team Camaro Tech
Non-Camaro Tech Problems and Issues with your daily driver or other non-Camaro vehicles.
post #1 of 5 (permalink) Old Nov 14th, 12, 04:13 PM Thread Starter
gary
Hi all can some one tell me if its a pain to replace the pump in the tank thanks guys
Real canadian67 is offline
post #2 of 5 (permalink) Old Nov 14th, 12, 04:24 PM
Chuck
Re: 2002 chevy avalanche fuel pump
I have not personally attempted this operation but I understand that it's relatively straightforward after you get the bed off the frame.
cnorton7311 is offline
post #3 of 5 (permalink) Old Nov 14th, 12, 04:39 PM
Josh
Not a big deal if you got time. If you are an experienced wrench, you can do it in an afternoon. If you are not so experienced in a day.
You'll need a floor jack to hold the tank up and move it up and down, and preferably a helper to help steady it when lowering/raising.
Hardest part is getting the lines and electrical connectors off without damage while balancing the tank halfway removed so you have enough room to get them off.
After that once it's out just clean the nut area well and unscrew. Make sure you replace the o-ring/boot. Lubricate nut and o-ring/boot with a little silicone spray on reinstallation.
If you have to have the pump out for some reason for longer than 30 minutes, reinstall the cap nut to keep it's shape.
Good luck!
Grabbin2ndgear is offline
post #4 of 5 (permalink) Old Nov 14th, 12, 04:51 PM
Roger
rogerh's Avatar
I have a 02 Avalanche and I have found some good info at this site.
Roger
http://www.chevyavalanchefanclub.com/cafcna/index.php
rogerh is offline
post #5 of 5 (permalink) Old Nov 15th, 12, 02:28 PM Thread Starter
gary
Thanks guys i have our machanic doing it as i have no time rite now and my son needs it to go to work, thanks for the replies
