My 09 avalanche troubles - Team Camaro Tech
Non-Camaro Tech Problems and Issues with your daily driver or other non-Camaro vehicles.
post #1 of 5 (permalink) Old Dec 22nd, 12, 12:36 AM Thread Starter
Steven
stamatisg1977's Avatar
Hey guys. On my way to work tonite my truck started bucking real bad and luckily I keep my scanner tool in the center console. I pulled code p0087 which is a low fuel rail pressure and another code that I think said fuel pump driver module. Anyway driving under load the fuel psi will read between 44-56 psi. But with the engine off/key on it climbs all the way up to 80psi. I took it for a quick spin when I could as it still bucked and hesitated under load, it did not drop any codes. Your thoughts??
I'm at work and scared to drive home in the morning lol
69 Frost Green Camaro
LS3 with TSP stage 3 cam
Tremec TKO 600
Ridetech rear 4-Link
Follow my journey here:
stamatisg1977 is offline
post #2 of 5 (permalink) Old Dec 22nd, 12, 07:50 AM
DjD
DjD's Avatar
Re: My 09 avalanche troubles
Just based on your description ir sounds like the fuel pump is bad...
...Dennis
DjD is offline
post #3 of 5 (permalink) Old Dec 22nd, 12, 03:25 PM Thread Starter
Steven
Drove it again today and I was watching the fuel pressure and it didn't go over 45 psi even under hard acceleration
Tremec TKO 600
post #4 of 5 (permalink) Old Dec 22nd, 12, 04:18 PM
Paul B
I think some of these vehicles had a problem with a flexible part of the fuel lines collapsing under load, which triggers the Poo87 code. Might be a TSB on it as well. Getting 80psi at idle and dropping to 44psi indicates a restriction or blockage. Fuel pressure regulator even.
paulsstuff is offline
post #5 of 5 (permalink) Old Dec 22nd, 12, 05:25 PM Thread Starter
Steven
I get 44 at idle. I think the 80 was just a glitch in my scanner. But while driving under load it never goes up past 44psi. But just now I gunned it and there were no symptoms/problems
Tremec TKO 600
