Larger exhaust or x-pipe. - Team Camaro Tech
Non-Camaro Tech Problems and Issues with your daily driver or other non-Camaro vehicles.
post #1 of 4 (permalink) Old Jan 9th, 13, 06:19 AM Thread Starter
I am torn here. I know that a 2.5" exhaust is good until 500hp or so but what is the flow difference between a 2.5" system with x-pipe and a 3" system without an x-pipe. I'm putting this system on a '72 Nova with a 450hp 383 (600hp 406 in the works) but I only want to do the system once. It's a drag car that can be driven on the street. Also, Im not putting tail pipes on. I plan on having the exhaust dump right after the muffler. I know this is a Camaro forum but I wanted your opinions.
Thanks for the help.
Mexirican is offline
post #2 of 4 (permalink) Old Jan 9th, 13, 10:26 AM
Vintage 68's Avatar
Cool Re: Larger exhaust or x-pipe.
I would think Muffler choice (for CFM requirements) and required system flow would be more important that X-Over sizing in your case.
But a properly sized and installed X-Over could increase high flow scavenging efficiencies and help top-end HP output.
Vizard wrote a very good flow article years ago for Popular Hot Rodding that had inputs from Joe Sherman and others on system design and sizing for given applications.
Try a search for Vizard Exhaust system sizing and see if Mr. Google can find it ...
1968 Convertible
Some trucks
Vintage 68 is offline
post #3 of 4 (permalink) Old Jan 9th, 13, 04:50 PM
a 3" X pipe with 2.5" pipes after it with good flowing mufflers will do the job.
you don't plan sincerity.
novaderrik is offline
post #4 of 4 (permalink) Old Jan 9th, 13, 10:27 PM
the BOSS&Ralph
Fitting an x pipe with a 3 system wasnt difficult on 69 Camaro. Im guessing your Nova would be similar. At 600 HP Id do 3 with X pipe. I did this on a 406 N/A small block with a guesstimated 525-550 HP (flywheel). The band clamps make transmission servicing easy.
For your current engine 2 , but for your next engine Id go big.
ID:	31716   Click image for larger version
friendlyviper is offline
