What size rear is this? - Team Camaro Tech
Non-Camaro Tech Problems and Issues with your daily driver or other non-Camaro vehicles.
post #1 of 19 (permalink) Old Jan 21st, 13, 09:45 PM Thread Starter
nope
I thought i had a 7.5 in my 79 caprice. Im told now it might be an 8.5. What do you think?
hotrodjunky1982 is offline
post #2 of 19 (permalink) Old Jan 21st, 13, 10:03 PM Thread Starter
nope
Pictures wont load.
Sent from my SCH-I510 using AutoGuide.Com Free App
post #3 of 19 (permalink) Old Jan 29th, 13, 08:32 AM
Re: What size rear is this?
Most likely it's a 7.5, unless it's a former police, fire or taxi. But even then.....
puff puff is offline
post #4 of 19 (permalink) Old Jan 30th, 13, 06:54 AM Thread Starter
nope
Turns out its a small bolt pattern 8.5
post #5 of 19 (permalink) Old Jan 30th, 13, 11:49 PM
And this is a 79 caprice?
post #6 of 19 (permalink) Old Jan 31st, 13, 02:34 AM
should be a 7.5, unless it's got a BOP 8.5 in it.. those are the ones with the goofy cover with the big indentations on each side and the pressed on axle bearings.
got any pics?
you don't plan sincerity.
novaderrik is offline
post #7 of 19 (permalink) Old Jan 31st, 13, 05:53 AM
Rich
look at the diff from the rear a 8.5" will have big ears at 7 and 5 o'clock the 7.5" has little spikey ears see below
69 R/S Z/28 302 X33 D80 late 09C
69 T/A clonification LS6-6speed under construction
15 ZL1
64 Chevelle wagon 6.0l planned sons toy
zman1969 is offline
post #8 of 19 (permalink) Old Jan 31st, 13, 06:12 AM Thread Starter
nope
Its the 8.5. I still dont get why i cant post pictures on this forum. The code on the rear tag reads 2LA-B 2.41. Ive found quite a few b bodies with the 2.41 8.5 rear. I was told they were basically leftover rears from the 73-77 chevelle. same attachment points for everything...supposedly the chevelle frame was pirated and slightly modified for the caprice.
post #9 of 19 (permalink) Old Jan 31st, 13, 07:23 PM
you can post pics by hosting them somewhere else and using "img" tags to link to them here.. facebook is a good place to host pics if you have an account- and if you want to put it here, you just look at the pic on facebook, refresh the page, right click on the pic, select "copy image location".. then come here, paste the url in between the 'img' tags, and it will show.. like this:
hit the "quote" button to see how it's formatted.. the url for the pic is in between the [img] tags..
and, yes, the 77-96 B body chassis is the 73-77 A body chassis with a few changes- the most significant of which is a stupid transmission crossmember design..
post #10 of 19 (permalink) Old Jan 31st, 13, 08:08 PM Thread Starter
nope
Just bought a 96 impala ss t56 crossmember for a swap into the 79. i have no facebook and no provlems posting pics in my other forums using autoguide
post #11 of 19 (permalink) Old Feb 2nd, 13, 01:50 AM
That may be true as the frames between the 2 models were similar if not identical. But then it also may be true that some swapped it in.
The "small" caprice had, at that point, been out for 2 models years. They had that many "leftover" 8.5 10 bolts?
i am personally not buying it.
post #12 of 19 (permalink) Old Feb 4th, 13, 06:26 AM Thread Starter
nope
Youre more than welcome to come to CT and use my creeper to see for yourself. The car is 1 owner and definately has the original rear, as i have spoken to and verified from the original owner. As a member of 2 impala, chevelle,buick, and camaro forums, that is what i have pieced together. "left over" or not, thats the rear its got.
post #13 of 19 (permalink) Old Mar 9th, 13, 08:33 PM
UPDATE:
Ok, i can't (and won't) speak for nova, but i was wrong; Apparently the b bodies up until at least 90 had the 8.5" 10 bolt. This is actually good to know.
2) The BOP 10 bolts stopped in 72, so that's out. Besides it's b.o. and p so.......
So, good for you and this is good info to know as b-bodies might be good rodding material now.
post #14 of 19 (permalink) Old Mar 12th, 13, 08:11 AM Thread Starter
nope
good to see you're coming around.
Sent from AutoGuide.com Free App
post #15 of 19 (permalink) Old Mar 12th, 13, 02:57 PM
The 8.5 in my Camaro is from a '79 Nova. V8 Novas in '79 got the 8.5, 6 bangers got the 7.5 - no reason to think the big cars would be any different.
BPOS is offline
