camaro front clip - Team Camaro Tech
Non-Camaro Tech Problems and Issues with your daily driver or other non-Camaro vehicles.
post #1 of 9 (permalink) Old Feb 18th, 13, 04:41 AM Thread Starter
gary
camaro front clip
Hi there guys can someone tell me if a 1979 camaro z28 front clip go on a 1955 chevy truck and can i use the disk brakes aswell, the tranny is a m22 4 speed with a 350,can i use the rear end also,how much work am i looking at. the truck has a 265 6 bagger with a 3 on the tree,Thanks Gary
Real canadian67 is offline
post #2 of 9 (permalink) Old Feb 18th, 13, 06:35 AM
keith
X-77 keith's Avatar
Re: camaro front clip
I have seen this done to a 60 truck. Measure the frames. It is going to take alot of measuring and welding. Where their is a will there is a way, but will be a big job.
X-77 keith is offline
post #3 of 9 (permalink) Old Feb 19th, 13, 06:26 AM
Did a check for you, and I think David T's got a '79 clip for sale. Don't know of the shape it's in, but would be a glove fit if good, eh?
Also sheck PM for question.
capt
captcanuck68 is offline
post #4 of 9 (permalink) Old Feb 19th, 13, 07:13 PM
Patrick
Yes it can be done. I have done it myself on 6 or 7 trucks. Here is a link.
http://www.jalopyjournal.com/forum/s...ro+swap+in+day
PDW HOTRODS is offline
post #5 of 9 (permalink) Old Feb 19th, 13, 07:40 PM
Paul B
Works well, but one thing I see quite a bit is the center of the spindle is either a little to far forward or back making the tire look a little off in the fender opening. Just a matter of getting your measurements and trial fit exact before welding.
paulsstuff is offline
post #6 of 9 (permalink) Old Feb 20th, 13, 06:01 PM
Patrick
Moving the center forward about 3/4 of an inch works good. Should test fit first though, with all front sheet metal on the truck.
post #7 of 9 (permalink) Old Feb 20th, 13, 08:11 PM
Absolutely. i have personally seen and ridden in one. Rides very well.
The key is to really measure anything.
i think if i was in the same position i would just get like a newer shortbed or blazer frame and go with that. Or really, the simpliest thing would be just to continue using the stock frame.
puff puff is offline
post #8 of 9 (permalink) Old Feb 21st, 13, 08:07 AM
What is the intended purpose and reasoning behind the swap?
post #9 of 9 (permalink) Old Feb 21st, 13, 05:39 PM
Patrick
The truck came with a straight axle, no power steering or disc brakes. After the swap it drives like a Camaro.
