Store bought prepped rear vs. salvage yard rear: - Team Camaro Tech
Non-Camaro Tech Problems and Issues with your daily driver or other non-Camaro vehicles.
post #1 of 8 (permalink) Old Feb 20th, 13, 02:54 PM Thread Starter
Discuss, contrast and compare the relative advantages and disadvantages and strength differences if any between buying a fully prepped, 100% bolt-in 12 bolt from moser or other vendors:
http://www.moserengineering.com/comp...figurator.html
Base price is $1925, but after you scroll thru the options (in some cases can't use the stock brakes) it goes up to about let's say $2500
VS.
Going the the junkyard and getting a 10 or 12 bolt out of a 1/2 ton truck for $65 drum to drum. Yes, it's possible here. And if the wheels stick out, putting flares over them, which i think actually looks cool if done right. This will, however, very probably ruin the re-sale value of the car, so we should maybe factor that in.
To focus in, the car in question either has a 7.5" 10 bolt or no rear at all. In cases where the car already has a 10 or 12 bolt it would probably most economical to work with the existing rear.
puff puff is offline
post #2 of 8 (permalink) Old Feb 20th, 13, 03:14 PM
Re: Store bought prepped rear vs. salvage yard rear:
The 12 bolt trucks are very diffrent, too wide 5" bolt pattern diffrent gears, wrong mounts. So now you need tubes, axles, brakes bearing, and limited brakes.
john68 is offline
post #3 of 8 (permalink) Old Feb 20th, 13, 03:51 PM Thread Starter
Well, i'm thinking i would run 5x5 bolt pattern wheels and as far as the mounts i would weld my own on and actually i was considering running ladder bars anyways so i would have to weld new mounts on regardless. i'm thinking this would still be much cheaper than the shop assembled rear.
Admittedly if i did got with the bolt in unit then i would just stick with the stock suspension---if camaro/nova i would stick with leafs and if montecarlo then the stock 4 link.
post #4 of 8 (permalink) Old Feb 20th, 13, 04:40 PM
the truck 12 bolts are weaker, too.. something about the pinion gear, i think? or maybe a bearing is smaller..
be better off to just find an 8.5 and go with that- it was good enough for GM to replace the 12 bolt in every application from Novas to 1/2 ton trucks in the mid 70's, and i think they still use an upgraded version of it to this day behind some pretty impressive engines in the 1/2 ton trucks and vans..
you don't plan sincerity.
novaderrik is offline
post #5 of 8 (permalink) Old Feb 20th, 13, 05:04 PM
or maybe even a Ford 8.8.. they are almost an exact copy of a 12 bolt right down to the ring gear size and some of the bearings used, and you will get probably get disc brakes if you get one out of an Explorer.. one from a Mustang almost bolts into a G body and can be adapted to other 4 link GM cars with a little work.. the wheel bolt pattern is smaller and they have 1/2" studs, but that's stuff that's easy to fix with either different wheels and lug nuts or a simple redrilling job at a local machine shop..
post #6 of 8 (permalink) Old Feb 20th, 13, 05:13 PM
Michael Gekko
If you are going to a junk yard to get a rear just get a 9 inch...Ford made millions of them, look for a 70's or 80's truck. Cut the axle tubes down. I haven't gone boneyard hunting in a long time, but in the '90s I cut probably a dozen out of old F-150 trucks...the most I think I ever paid for one was 100 bucks, sometimes a 50 would get it. The 9 inch rears in Lincolns usually had disc brakes too.
You can also find some of the 70's style Trans Ams in junk yards, they have the big 10 bolt with a posi and disc brakes too. I think all of them came like that, but not sure.
Eleanor's Nemesis is offline
post #7 of 8 (permalink) Old Feb 20th, 13, 05:14 PM
Michael Gekko
I think it's both the bearing is smaller and the pinion is smaller. Maybe Freddie will stop by.
post #8 of 8 (permalink) Old Feb 20th, 13, 05:25 PM
Banned
Chet
The Moser and Strange pieces are far superior to any factory piece. To do all the things to a junkyard rear end to try and make it the equal in strength to the Moser or Strange would cost the same or more than what they charge for a full custom piece. Read the specs and features again.
154567 is offline
