Kent Moore J 39580 - Team Camaro Tech
Non-Camaro Tech Problems and Issues with your daily driver or other non-Camaro vehicles.
post #1 of 11 (permalink) Old Feb 27th, 13, 02:42 AM Thread Starter
KEN
Kent Moore J 39580
Hello everyone, Well I need to change the motor in my 2005 uplander van. I need to find a kent moore J-39850 engine support table used or see if there is anything anyone on here would suggest using. It would be nice to get the deminsions if I could to build one. I just cant spend $1150 on a cart I might only use once. Thanks in advance.
ken
69 camaro ss (hope to drive some day)
camaroman3 is offline
post #2 of 11 (permalink) Old Feb 27th, 13, 04:38 AM
Bob
Re: Kent Moore J 39580
Seems like an absurd amount of money for an engine stand. Why not just sit the engine/trans assembly on a pallet or flat cart and ratchet-strap it down? Once it's out from under the van, you can break the trans free and sit the engine on a standard engine stand.
BobKovacs is offline
post #3 of 11 (permalink) Old Feb 27th, 13, 04:48 AM
Movers dolly?
TC # 349
zdld17 is offline
post #4 of 11 (permalink) Old Feb 27th, 13, 10:19 PM Thread Starter
KEN
Thanks for the replies. If anyone else has any other ideas please post. I just want the easiest that's for sure. Thanks
ken
post #5 of 11 (permalink) Old Feb 28th, 13, 07:30 AM
4 jackstands work great,
john68 is offline
post #6 of 11 (permalink) Old Feb 28th, 13, 09:44 PM Thread Starter
KEN
Well the jack stands would hold it but then how do you get it out from under car. Here is what i need. maybe this will explain it a little more.
http://www.toolsource.com/engine-sup...-p-111737.html
ken
post #7 of 11 (permalink) Old Mar 1st, 13, 06:38 AM
We used that engine support all the time. You need a rack, to lift the car over the engine, then move the engine around. or just work under the car.
john68 is offline
post #8 of 11 (permalink) Old Mar 1st, 13, 02:17 PM
Chris
Buy a 4 leg engine stand. Cut it up and weld it to give you the lower box so you have the box with the wheels then maybe weld some jack stands in the corners.Either way your going to need to get the front up high enough to wheel it out.I would figure out a way to lift the front of the van and roll it back over the engine.Hoist maybe? Maybe set the engine on a pallet jack and lift the front of the van real high and pull the jack out with the engine on it.
shoddy_F-body is offline
post #9 of 11 (permalink) Old Mar 1st, 13, 02:54 PM
Vintage 68's Avatar
Wink Re: Kent Moore J 39580
We used a trans jack with a welded angle iron support structure to fit under engine oil pan rails to support it - worked like a charm and was very easy to adjust the fit.
Think the metal cost less than $20 - and already had a trans jack, but they are available for way less than $1,200
Try visiting your local Harbor Frieght Tool and see what they have.
1968 Convertible
Some trucks
Vintage 68 is offline
post #10 of 11 (permalink) Old Mar 4th, 13, 09:38 PM Thread Starter
KEN
Thanks for the ideas I will get started on it and figure something out. Thanks
ken
post #11 of 11 (permalink) Old Mar 4th, 13, 11:59 PM
Steiner
Fab up a cradle on a motorcycle jack?
http://www.sears.com/shc/s/p_10153_1...&%20Jacksmv=rr
'69 Camaro
500hp/538lbft
Steiner is offline
